I've got a tick
Old Nov 27, 2012 | 09:32 PM
MGK's Avatar
MGK
Default I've got a tick
I've got a 78 350 w "summit racing" heads with a not real loud but distinctive tick . Appears to be loudest by the distributor. Could it be the oil pump? Not sure I have a problem or not. What should I be looking for or checking?
Old Nov 27, 2012 | 09:52 PM
TimAT's Avatar
TimAT
Pop the rocker covers and take a close look at the pushrods where they disappear thru the head. If the tick seems to speed up with RPM there have been cases of the pushrods hitting the guideplates or the heads.
This may seem silly, but also check your distributor cap. I've seen a couple that were not seated correctly and the engine ran fine, but the rotor was hitting the cap. How long they would have run like that is a question, but they did tick.
Ckeck your plug wires too- a spark jumping somewhere it's really not supposed to can sound like a tick also. Usually accompanied by a miss, but not always. I've seen a few coils that were arcing inside and while you couldn't see the arc, you could hear it. I've found, for secondary ignition, that a spray bottle with water and a couple drops of dish soap makes a good tool for finding leaks.
Old Nov 28, 2012 | 07:57 PM
MGK's Avatar
MGK
I'll give that a try
Old Nov 29, 2012 | 12:57 AM
Teem66's Avatar
Teem66
My ticking noise was caused by the sound of arcing between the coil and the distributor body. I could see it with the coil cover off.
Old Nov 29, 2012 | 01:16 AM
scottyp99's Avatar
scottyp99
If you take a piece of old heater hose and stick one end up against your ear, you can use the other end to do a pretty good job of tracking down where a noise is coming from.
Scott
Old Nov 29, 2012 | 07:49 AM
Doug1's Avatar
Doug1
Scott
what are you doing up so late!?
To I've got a tick
