74 Power brake booster nut help
Old Dec 2, 2012 | 10:32 PM
SLAZ06's Avatar
SLAZ06
Default 74 Power brake booster nut help
I need to replace the power brake booster on my 74 but can not see or find the upper drivers side nut. Even with the dash off no luck. I got the other three OK but I'm stumpted. Any suggestions. Thanks
Old Dec 2, 2012 | 10:42 PM
Torkman's Avatar
Torkman
Did you pull off the black plastic air tube? If so, the bolts are all pretty easy to see. Read my post on removing them...all four took about 5 minutes.
