What the Hell is this
Old Dec 7, 2012 | 02:13 PM
jagvette's Avatar
jagvette
Default What the Hell is this
Girls and Guys
Do you have any idea what this is ?, I am working on a car for a friend and the battery is being slowly drained, I narrowed it down to this item but do not have a clue what it is or what it does.
The numbers on it are 463498 and 913.
Please click on link to view box.
http://forums.corvetteforum.com/albu...ctureid=128283
The board inside seems to be burnt in one area and I 'assume' this is what it is draining the battery.
Gary
Old Dec 7, 2012 | 02:21 PM
Lil" Red Corvette's Avatar
Lil" Red Corvette
Isn't that the little module that delays your interior lights? I think the newer C3s did that but I am not sure.
Old Dec 7, 2012 | 02:25 PM
Mike Ward's Avatar
Mike Ward
LMGTFY
http://lmgtfy.com/?q=463498+Corvette
Old Dec 7, 2012 | 02:58 PM
power shift's Avatar
power shift
It's your time delay.
Roco71's Avatar
Roco71
Originally Posted by Mike Ward
That's really cool Mike
Old Dec 7, 2012 | 03:36 PM
John 1971 LT-1's Avatar
John 1971 LT-1
4th Gear
That is cool. I do technical support and half the stuff is on google.
Old Dec 7, 2012 | 03:42 PM
jdp6000's Avatar
jdp6000
How did you make it do that?
Jim
Old Dec 7, 2012 | 03:48 PM
jim-81's Avatar
jim-81
Jim
you could probably just Google and find out! haha...
Old Dec 7, 2012 | 03:49 PM
jagvette's Avatar
jagvette
Default Your good
Damn you guys are good, what amazing and speedy response, my follow up question is what happens if i do not bother replacing it and leave it out.
do the lights just not work ?
thanks
Gary
Old Dec 7, 2012 | 03:52 PM
briankeery's Avatar
briankeery
Bypass the delay timer by connecting the white wires on the connector. Lights will automatically come on when door opens......problem solved.
Old Dec 7, 2012 | 03:58 PM
Lil" Red Corvette
Gary
I was first!!! Give me a cookie. Give us another one.
Old Dec 12, 2012 | 09:33 AM
John 1971 LT-1
4th Gear
C3 Interior Light Delay Timer 1978-1982
http://www.corvettesalvage.com/index...oducts_id=1075
Old Dec 12, 2012 | 09:55 AM
Corvette Don's Avatar
Corvette Don
Where is that timer located?
Old Dec 12, 2012 | 10:00 AM
gbvette62's Avatar
gbvette62
In the right hand side of the dash. Remove the glove box liner, and it will be tucked up in the dash, to the right of the liner.
Old Dec 12, 2012 | 05:43 PM
72LS1Vette's Avatar
72LS1Vette
If that module turns out not to be the source of the drain, connect an ammeter between a battery terminal and cable and remove one fuse at a time until you find the circuit that has the drain. After that you will need a wiring diagram to look at each component in the circuit.
Rick B.
Old Dec 12, 2012 | 10:09 PM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
You're all wrong thats the Continuum Transfunctioner.
Things will never be the same now......
Old Dec 13, 2012 | 08:48 AM
RonR80's Avatar
RonR80
St. Jude Donor '09
Wow Mike you have outdone yourself now that was cool ,
Old Dec 13, 2012 | 09:23 AM
jdp6000's Avatar
jdp6000
Okay....I figured it out. Thats cool!
Just go to http://lmgtfy.com/
To What the Hell is this
