Throttle return spring with TV MADE EZ kit ?
Old Dec 7, 2012 | 09:18 PM
johnt365's Avatar
johnt365
Default Throttle return spring with TV MADE EZ kit ?
I am installing the TV Made EZ kit from Bowtie Overdrives on to my Holley 4160 carb. If anybody has this system, where does the throttle return spring connect? BTO does not specify and their bracket does not have a provision to connect a standard length spring.
So, as you can see in the pic, I have a third party throttle bracket installed for the spring. The second issue is now my drop base air cleaner will not fit. How did you connect your throttle cable and and return spring with the BTO TV kit?
I wonder if they sent me the wrong adapter plate.
Thanks,
Old Dec 7, 2012 | 10:13 PM
johnt365's Avatar
johnt365
Here is the Bowtie od throttle bracket. Just need a return spring idea.
Old Dec 7, 2012 | 10:55 PM
oldalaskaman's Avatar
oldalaskaman
post #4 seems to have his springs running to the front of the engine from the big linkage hole.
http://www.google.com/url?sa=t&rct=j...YlleT5AaVlMGww
you could also make an upright bracket from one of the manifold bolts
Old Dec 7, 2012 | 10:59 PM
oldalaskaman
http://www.google.com/url?sa=t&rct=j...CKKFUVifAxfzVQ
like this
Old Dec 7, 2012 | 11:30 PM
johnt365's Avatar
johnt365
gotcha. I need some kind of front mount solution either a bracket to the manifold or the carb. thanks
Old Dec 8, 2012 | 12:22 AM
Lil" Red Corvette's Avatar
Lil" Red Corvette
I have the same BTO kits and bought one of those chrome brackets (spectre I think) and bolted it to the manifold in front of the bracket.
As far as the breather clearance issue. Which part is hitting? I have a Q-Jet and a L-88 base on mine so I may not be able to help you but I did end up having to grind a little off the top of the throttle bracket and I have a 1/2 spacer between the carb and base. But, with the L88 hood I have a bunch of clearance.
Old Dec 8, 2012 | 12:54 AM
oldalaskaman
Hey john, check out the setup in the other thread thats running's brackets
Old Dec 8, 2012 | 01:53 PM
johnt365's Avatar
johnt365
Here is what I ended up with. Thank you all for the ideas, I was stuck in my head but think this is a decent solution.
I had a couple of these little metal brackets that probably came with a ceiling fan or something about 15 years ago. I cut and drilled it out. Then made another piece to attach the spring to on the linkage.
yeah... its adjustable.
Should be good enough for functionality.
Thanks again.
To Throttle return spring with TV MADE EZ kit ?
