Today is the day!!
Old Dec 8, 2012 | 01:37 PM
82CEFan's Avatar
82CEFan
Default Today is the day!!
The new shocks have arrived. It is finally time to replace the 30 year old ones. KYB's all around
Old Dec 8, 2012 | 04:02 PM
johnt365's Avatar
johnt365
be like havin a new car.
Old Dec 8, 2012 | 08:19 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Well, how did it go? How does it ride?
Old Dec 8, 2012 | 08:52 PM
82CEFan's Avatar
82CEFan
Much better ride. Additional suspension parts will be needed. starting to see some wear on the parts
Old Dec 8, 2012 | 09:49 PM
qwank's Avatar
qwank
replace it all
Old Dec 9, 2012 | 01:35 AM
82CEFan's Avatar
82CEFan
That is the plan. Will be a great winter project
Old Dec 11, 2012 | 12:25 AM
82CEFan's Avatar
82CEFan
Ordered front suspension rebuild kit this evening. now the waiting begins
Old Feb 20, 2013 | 10:57 PM
82CEFan's Avatar
82CEFan
Well the new front bushings and ball joints are in, replaced the heater tube, and mounted the AC compressor correctly i am finally ready to take the car in for an alignment and see how the car rides now.
Old Feb 21, 2013 | 06:31 AM
MrJlr's Avatar
MrJlr
Ttt
Old Feb 21, 2013 | 08:32 AM
johnt365's Avatar
johnt365
I don't want to jinx you, but how do your rear trailing arm shims look? When I went for an alignment, the shop game me some home work. Since its a 4 wheel alignment, you should also check the rear strut rods and the strut bushings, they control the rear camber. Then make sure the trailing arm shims move free and the bolt can turn, those shims control the rear toe. If not, they will probably just do a front alignment.
Old Mar 27, 2013 | 12:06 AM
82CEFan's Avatar
82CEFan
only did front end suspension so far. Car is much smoother over the bumps.
To Today is the day!!
