Electric window motor
Old Dec 10, 2012 | 10:32 PM
chippy126's Avatar
chippy126
Cruising
Default Electric window motor
How do you adjust the travel on the window motor of a 79? The down stop works fine but the up is two inches short and just makes a noise like it ran out of threads or something.
Any helpful ideas?
Old Dec 10, 2012 | 10:56 PM
stumpshot's Avatar
stumpshot
Possibly a stripped regulator gear. Does the window go all the way up if you help it up with your hand? If so, the regulator gear teeth are stripped and you'll need to pull it and probably the electric motor to repair with either a new regulator or motor gear or both.
All this is provided it's built like my '75.
Check around the site for more info as the regulator can ding you and the car if you're not careful.
Good luck.
Stump
Old Dec 10, 2012 | 11:04 PM
chippy126's Avatar
chippy126
Cruising
You have to pull it up the rest of the way.
Old Dec 11, 2012 | 07:29 PM
stumpshot's Avatar
stumpshot
Sounds like the regulator gear. In that case the motor and regulator should be removed so as to check the teeth on both. Check out corvettecentral and search their site for C3 window regulator replacement. A stainless regulator repair gear is available for many of theC3's. It requires drilling some small holes and bolting it over the original gear. Otherwise you must replace the regulator itself. I always remove the motor and regulator as one unit along with all the rest of the window junk so I can clean everrything at the same time.
Hope this goes well for you.
Stump
Old Dec 11, 2012 | 07:43 PM
chippy126's Avatar
chippy126
Cruising
Thx Stump. Will I have to tear the door in half to get at this?
Old Dec 11, 2012 | 08:30 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
It is the regulator gear or motor gear for sure. The restriction is the upper stops located in the top of both the front and rear run channels. If it's not making it to them then you have to have a gearing issue.
Replacement gears are available.. but I suggest you get a new regulator and make darn sure it's the us made one. Why the regulator... well you can buy new rollers for it and you can buy rebuild kits for it but to me it's a time vs. money thing. When you get new you install and go. The time to remove the old gear, weld on a new one, replace the rollers (if needed) just doesn't seem to work to your advantage.
And another suggestion if you go with just the gear... make sure you bolt the gear to the regulator before you remove the power window motor.
You'll find all the parts for rebuilding or replacement at this link --> HERE
Willcox
Old Dec 11, 2012 | 08:33 PM
Peterbuilt's Avatar
Peterbuilt
Here's a How To:
Sounds like you need a gear but they don't show how to repair the gear.
http://www.corvettemagazine.com/1968...power-rebuild/
The gear replacement is "F".
Half apart, more like 90%.
Might as well remove and oil up the lock while your in there.
Old Dec 11, 2012 | 08:38 PM
69FASTFUN's Avatar
69FASTFUN
While you have the motor out clean all of the 30 to 40 year old grease out and put in new.
Old Dec 11, 2012 | 09:49 PM
chippy126's Avatar
chippy126
Cruising
Great information. How do you get the inside half of the door off?
Thank you all! Pete! Great photo of the breakdown
Old Dec 12, 2012 | 12:17 AM
stumpshot's Avatar
stumpshot
Chip- If the 79 is the same as a 75 the door panel is held to the door by
a screw at the top front corner and a screw at the top rear corner. They are easy to see and go straight into the door. There are 2 more screws that go through clips at the bottom of the door. Flop down on your back and look under the door and near the rear bottom of the door if I remember correctly. I don't remove the door handle but pull it out to the open position and slide the door panel forward over it. My door handle screws are frozen tight so it's easier for me to slide the panel off than screw up an original door handle. I use a long wire tie around the door handle and through the door panel hole to facilitate holding the handle while I remove and install the panel.
Take it slow and things should be just fine------frustrating at times---- but you'll get it.
Stump
Old Dec 12, 2012 | 08:39 AM
AT-82Collectors's Avatar
AT-82Collectors
Was just there and did that on my 82. Here is the thread:
http://forums.corvetteforum.com/c3-t...-question.html
You may find some of this thread helpful.
Andy
To Electric window motor
