reverse gear popping out
Old Dec 11, 2012 | 12:30 AM
mauidave's Avatar
mauidave
Cruising
Default reverse gear popping out
I just bought a 1973 corvette convertible, I have had it for about a week now, and now I have noticed that when I put it in reverse, it slides back out. Also, I am now unable to put the key in lock position since the car needs to be in reverse to put it in lock. Can anyone please help me with a suggestion? Thanks in advance!
Old Dec 11, 2012 | 05:50 AM
69small block's Avatar
69small block
Default popping out of gear
could be the bolt that holds the lever to the trans is loose or worn
Old Dec 11, 2012 | 06:44 AM
Indiancreek's Avatar
Indiancreek
Take a look at wear and adjustment of your shifter arms.
Old Dec 11, 2012 | 09:34 AM
gcusmano74's Avatar
gcusmano74
Yes. Step one is to adjust the linkage.
Old Dec 11, 2012 | 12:27 PM
A88FXRS's Avatar
A88FXRS
next step is to check the reverse drive cable which controls the steering column and allows the key to rotate fully and be removed.
Old Dec 11, 2012 | 01:50 PM
69ttop's Avatar
69ttop
if you have a factory shifter you have to use a neutral key that slides through and aligns all 3 linkage arms on the shifter and with the trany arms in neutral position make your linkage adjustments.
Old Dec 11, 2012 | 08:37 PM
mauidave's Avatar
mauidave
Cruising
Thanks to all who gave me a start at trying to correct the problem I appreciate the help.
To reverse gear popping out
