spare tire
Old Jun 10, 2002 | 12:28 AM
myl82's Avatar
myl82
8th Gear
Default spare tire
Hi everyone! just got my first Vett. its a 1979 L82 CR 4 speed. the Vett came without a spare tire, could someone advise the correct size to fit the carrier? thanks :smash:
Old Jun 10, 2002 | 01:59 AM
razz1980's Avatar
razz1980
Default Re: spare tire (myl82)
first welcome to the forum :cheers: a lot of the vette owners take the spare tire and holder off and just carry around a can of fix a flat :jester atleast thats what i do since mine never came with one either..go to e-bay there always for sale there and there should be a tire size in there add..
Old Jun 10, 2002 | 02:46 AM
Rockn-Roll's Avatar
Rockn-Roll
I'm using a 225/70-15, but it's a bit too thick. I would recommend a 215/70-15 for the spare.
Old Jun 10, 2002 | 02:59 AM
theanswriz42's Avatar
theanswriz42
Cruise-In 8 & 10 Veteran
St. Jude Donor '08, '15
Default Re: spare tire (Rockn-Roll)
Stock the spare tire was a fabric bias ply P195/80D15 but i wouldn't reccomend you use a tire that small in there unless you're going for originality.
:cheers:
Old Jun 10, 2002 | 09:28 AM
jerryp58's Avatar
jerryp58
Welcome to the Forum :seeya
I've read warnings here on the forum that you shouldn't run two different size tires (don't know how different) on the back of the car because it could cause problems for the differential.
What size tires do you have?
Do you still have the spare tire carrier?
Do you still have the jack?
Old Jun 10, 2002 | 07:29 PM
myl82's Avatar
myl82
8th Gear
thanks for everyones help. i belive i will go with the 215/70-15 and a can of fixti!
no i do not have a jack yet but working on getting one.
thanks, and this fourm really works! :seeya
Old Jun 10, 2002 | 07:56 PM
PROSOUTH's Avatar
PROSOUTH
From: Manchester, Dead Center in the Middle of TN 25 miles to Jack Daniels,10 miles to Geo Dickle, and .8 mile from the Liquor Store at I-24 Exit 114
St. Jude Donor '05
I have a new spare from my '80 that has never been on the ground and a Jack and tire tool/grommet and with the spring to hold it in with. E-Mail me if you are interested. JIM :seeya
Old Jun 10, 2002 | 08:09 PM
Robert N's Avatar
Robert N
Default Re: spare tire (PROSOUTH)
Using 2 different size tires on the rear (or front) can cause problems. Smaller spares were designed as space and weight savers for limited use. They are safe and usable to get you short distances at low speeds.
Old Jun 10, 2002 | 10:09 PM
myl82's Avatar
myl82
8th Gear
thanks! i would be. :crazy:
Old Jun 11, 2002 | 08:51 PM
myl82's Avatar
myl82
8th Gear
PROSOUTH please check your email. i am interested :smash:
Old Jun 11, 2002 | 11:17 PM
PROSOUTH's Avatar
PROSOUTH
St. Jude Donor '05
You must have sent it to the wrong address, try this....
PROSOUTH@ Charter.net
OR
ONEALS@Charter.net
JIM :seeya
Old Jun 11, 2002 | 11:20 PM
PROSOUTH's Avatar
PROSOUTH
St. Jude Donor '05
TTT :smash:
Old Jun 12, 2002 | 03:24 AM
76Pitter's Avatar
76Pitter
Previous tire sizes mentioned in this post will fit. They will have a slightly higher profile. You do not want to run too far on the different size spare as it does stress the rear end and U-joints. Safety note is that the spare tire is part of the built in crash protection in case you are thinking of removing it.
Old Jun 12, 2002 | 08:51 PM
myl82's Avatar
myl82
8th Gear
Default Re: spare tire (76Pitter)
hopefuly i won't need it ! but if i do it will not be on long. :rolleyes:
To spare tire
