Externally balanced flywheel
Old Dec 14, 2012 | 01:05 PM
drwet's Avatar
drwet
Default Externally balanced flywheel
I have the engine out of my '79 to fix some oil leaks and a general cleanup. Sometime in the future I want to convert to a five speed. While the engine is out I'm planning to buy a flywheel and get it balanced to match the flexplate from the automatic. (The engine is an externally balanced 383.) That way it won't hold me up for a couple of weeks when I do the transmission swap. I'm having trouble finding a quality externally balanced 10.5" flywheel. The best I seem to be able to do is to use a neutral balance flywheel and add a bolt on weight to it. Does anyone have any experience with this arrangement?
Also I have used lightweight flywheels on some of my other cars in the past and I like the way they rev. What is the prevailing opinion about flywheel weight in a Corvette?
Old Dec 14, 2012 | 01:23 PM
MIKE80's Avatar
MIKE80
You could get a Fidanza aluminum (neutral balance) with the balance plate option. I have an internal balanced 383 with the Fidanza and like the quicker revs.
