crossmember
Old Dec 18, 2012 | 07:29 PM
wantingc2's Avatar
wantingc2
6th Gear
Default crossmember
I am sure this has been discussed plenty of times before - but putting th 350 in a 1982 looking at g force crossmember , was wondering if anyone has used this item . Thanks
Old Dec 18, 2012 | 08:30 PM
doctorgene's Avatar
doctorgene
Yes Sir; I used a cross member from a 1980. I had to cut slices out & welded them back in, to miss the floor, which was made for the power seat unit. Everything bolted right back in, without any trouble. But it was very cheap fix, I think I could of used the 700 R member with a little welding also. But I wanted to save it for a future change. LOL Sorry, I have not used a g force unit. I didn't know they made these. Have a great day. Gene
Old Dec 19, 2012 | 08:20 AM
LastC3AZ's Avatar
LastC3AZ
we used the G-Force replacement on our 82 to allow for true duel exhaust ..... but still used the 700 R4 ..... not certain why you would want a TH350 ..???
It bolted right in with minimal adjustments .......
Old Dec 20, 2012 | 06:00 PM
Kelso's Avatar
Kelso
I was not aware the G-Force made a cross member. I just looked at there site and did not see any listing for one. Do you have a link?
Old Dec 21, 2012 | 08:49 AM
LastC3AZ's Avatar
LastC3AZ
http://www.transmissioncenter.net/gf...RPAodrToAbA#C3
Old Dec 21, 2012 | 01:17 PM
iokepakai's Avatar
iokepakai
Sure did on a Richmond 6 spd swap..Used the crossmember for the 700R4,just had to trim a little and drill new bolt holes..Solid well built unit.
[IMG][/IMG]
[IMG][/IMG]
To crossmember
