4.5" Back Spacing
Old Dec 20, 2012 | 06:33 PM
FlyLS6's Avatar
FlyLS6
Default 4.5" Back Spacing
Would an 8", 15" wheel, with 4.5" of back spacing, cause load issues with either spindles or bearings, front or rear?
Not concerned with the brake cable interference on this question. Although, would be interested on any other clearance issues, front or rear, that might pop up. Tires would be 245 or 255 60 15s.
Old Dec 20, 2012 | 07:53 PM
Sidepiper's Avatar
Sidepiper
I'd say your in the safe zone.
Old Dec 20, 2012 | 08:49 PM
3JsVette's Avatar
3JsVette
I'm sure you know 4" is the perfered backspace but I agree with the previous post and think you should be fine. Though you may want to experiment between the 245s and 255s to see what fits and looks better if that's possible.
Old Dec 21, 2012 | 08:33 AM
oldalaskaman's Avatar
oldalaskaman
might sit inside your fender...just a bit
Old Dec 21, 2012 | 09:21 AM
gkull's Avatar
gkull
I used 4.5 bs 15X9 centerlines for about 100,000 miles.
More BS is actually easier on bearing loading. When you have 4.5 the rear is fine the front you have to worry about tire diameter because lock to lock can touch the frame
Old Dec 21, 2012 | 11:22 PM
FlyLS6's Avatar
FlyLS6
Default Backspacing
Thanks for the feedback.
Old Dec 22, 2012 | 09:31 PM
texasbaehr's Avatar
texasbaehr
4.5 Will work fine on the rear but you will rub in the front when the wheel is turned to full lock. a 1/4" spacer on the front solves the problem and still allows enough thread engagement on the studs for safe wheel mounting. There are extended shank lug nuts available that allow more thread engagement with spacers.
Old Dec 23, 2012 | 12:02 AM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
I'm sure you can do the math, but Captain Obvious won't leave me alone until I point out that using 8" rims with 4.5" BS instead of 4" BS on a C3 will reduce your track width by 1" and set your tires/wheels further within the fenders by 1/2".
To 4.5" Back Spacing
