81 Choke question
Old Dec 23, 2012 | 11:03 PM
81NcVette's Avatar
81NcVette
Default 81 Choke question
I've noticed that my choke light does not ever come on and I had two quick questions...
1) Under exactly what conditions does the choke light come on... is it when the choke heater is warming up the carb, just until the choke is released? Is it under the control of the CCC (my CCC has been removed, so that could be my problem right there).
2) Where exactly is the "Choke Heater Relay"? I see it in my wiring diagram, but I'm not sure where it is physically located. And what is its purpose?
Thanks for any info.
Old Dec 24, 2012 | 12:11 AM
SIXFOOTER's Avatar
SIXFOOTER
The choke light indicates a loss of power to the choke heater. The relay is under the console
Old Dec 26, 2012 | 08:32 AM
LannyL81's Avatar
LannyL81
I disagree that the "CHOKE" lite indicates a loss of voltage/current to the choke heater. My lite comes on every time and then goes off when the choke heater relay kicks-off....which is about 10 seconds or less.
Old Dec 26, 2012 | 01:56 PM
SIXFOOTER's Avatar
SIXFOOTER
True, it comes on at start up but should go off right after
Old Dec 26, 2012 | 02:25 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Yep.
To 81 Choke question
