question about pre oiling
Old Jun 10, 2002 | 09:44 PM
Turbo-Jet's Avatar
Turbo-Jet
Default question about pre oiling
i was able to spin the pump with my 12v cordless and get about 23-25 psi, but after 5 min, no oil was coming to the valves. how long does it take? is that enough pressure?
Old Jun 10, 2002 | 09:53 PM
Gordonm's Avatar
Gordonm
Default Re: question about pre oiling (Turbo-Jet)
Keep spinning it. It will take some time but it will come out of the pushrod holes through the hole in the rocker arm.
Old Jun 10, 2002 | 09:57 PM
Pete79L82's Avatar
Pete79L82
It depends on the type of preoiler you are using. If it is the type that is just a shaft and a collor to sit in the intake you may never get oil to the pushrods. If it has a housing that looks like a distributor housing then it will seal off the internal passages and you should have oil in less then 5 minutes.
Turbo-Jet's Avatar
Turbo-Jet
Default Re: question about pre oiling (Gordonm)
ok, time to recharge batterey. it is 10W-40, and not very warm here (17 degC)
thanks
To question about pre oiling
