Pedal Mounted Kickdown Switch
Old Dec 25, 2012 | 12:51 PM
Torkman's Avatar
Torkman
Default Pedal Mounted Kickdown Switch
The kickdown on my car is intermittent. I located the switch by the pedal and saw that when the pedal is full floored the switch is only about half way pressed. I added some rubber hose to the round part of the switch and that bought me about 1/4" of additional travel. Test drive still only had two times where it would kickdown and then nothing. Two issues I need help on:
1. Is the movement of the switch one continuous slide or are there two positions...my switch appears to move down past a detent and then return to that detent. Only with a little push from my hand does it return back to the fully closed (resting) position. Is that normal or should it have a smooth, full slide the entire length of the switch slide both directions?
2. Tied a piece of string to the switch and drove it...once it was cruising in third gear, pulled the string, activating the switch, nothing happened...no down shift. Should the tranny downshift whenever that switch is activated or does it also require some vac change when pedal is WOT?
With the key turned on I understand I should hear a click when the switch is activated...I do not.
So, bad switch?
Old Dec 25, 2012 | 01:21 PM
TimAT's Avatar
TimAT
The click is the solenoid in the trans opening. If you don't hear it there's a problem. IT's possible your switch is worn and the contacts are passing each other insode the switch. Too much travel.
Old Dec 25, 2012 | 01:27 PM
JimT's Avatar
JimT
You should be able to hear the detente switch in the tranny operate. You may need to check the wiring from the pedal switch down to the tranny. My kickdown never worked so upon investigating I found:
1. Over the years the gas pedal had been bent so the pedal switch was not fully operating (solution was to reach down and pull back/up on the gas pedal till the switch would become fully engaged)
2. The wiring plug at the tranny housing was broken so no current was reaching the detente switch (I replaced the plug and verified connections)
3. I had a defective detente switch (I replaced for <$20)
good luck
Old Dec 25, 2012 | 02:30 PM
Torkman's Avatar
Torkman
I took the switch off the pedal mount. No continuity when switch moved. It comes apart pretty easy. The inside had dry gunk in it...looked like the slide grease was dry and hard. Cleaned it out and reassembled. Good bench continuity. Put back on pedal bracket, turned on key, activated switch, nice noticeable tranny click! Now I have nice kick down!
Thanks for everyone's help.
Old Dec 25, 2012 | 03:56 PM
'75's Avatar
'75
Had to do this to mine a few years back.
Old Dec 26, 2012 | 07:17 AM
JimT's Avatar
JimT
Fantastic, nice job!!!!!
Old Dec 26, 2014 | 12:49 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
I searched and found this old thread........
Does anyone have a "tip" for a '68 convertible that has been converted to a TH400....
There is no bracket-whatever on the accelerator pedal for a kickdown switch.....
Can I just install a switch there...or do I need a bracket?
(I am able to make up a wiring harness/no problem)
Thanks for any info.
Old Dec 26, 2014 | 08:37 PM
Mooser's Avatar
Mooser
Impress the next owner and put on on from a late 60s early 70s truck, they mounted on the carb
M
Old Dec 26, 2014 | 08:46 PM
Mooser's Avatar
Mooser
Just looked and it's another 68-69 only part
Time to get out the welder and start some fab work
A quick look at some photo's and I'm not sure why a later model bracket wouldn't fit...
M
Old Dec 26, 2014 | 11:14 PM
doorgunner's Avatar
doorgunner
M
M
Thanks.....since the project is a resot-mod....I'll put one "on the gas pedal"....I'm trying to keep the carb uncluttered/may as well clutter the gas pedal
I saw some switches on the web/I'll "re-look" for them.
Old Dec 26, 2014 | 11:26 PM
Mooser's Avatar
Mooser
I was only joking about the carb switch (although I have seen them)
If you google
Corvette Original TH400 Automatic Trans Kickdown Switch w/Bracket 1968-1969
You'll find a bunch of pics of what an original one looks like (big city) and then compare with the later ones are a chevelle one, may work out for you.
With the number of guys doing the auto - manual swaps, there should be some available
M
Old Dec 27, 2014 | 09:35 AM
doorgunner's Avatar
doorgunner
If you google
M
Will do.........(NOT the carb switch though )
To Pedal Mounted Kickdown Switch
