L46 350cid engine
Old Dec 28, 2012 | 09:29 PM
1968-72 Corvette PR's Avatar
1968-72 Corvette PR
Default L46 350cid engine
I have a question about the 350cid L46 engine in 1969-72 Corvettes. Before going to my question, however, I would like to take the time to say some things about the L46 engine.
The L46 is a better engine than many people realise. I know that the LT1, LS5, LS6 and others are ranked above, and have more hp than the L46, but the L46 is still one heck of an excellent engine ! People rave about the LT1, and with justified reason, but the L46 is truly excellent ! In 1969 and 1970, the L46 pumped out 350hp, one per cubic inch ! The L46 is a small block engine, lighter, nimbler, for better weight distribution and handling than the relatively cumbersome big block counterparts. People rave about big block engines, but they result in heavy-nosed cars. The L46 could be had with AC, not available with the LT1 (except for 1972, when the LT1 finally could be had with AC). The 1970 Corvette L46 pumped out 50 more hp than the 1970 Camaro SS 350. There was a 1970 Camaro SS 396 that pumped out 350hp, just like the 1970 Corvette L46, but the 1970 Corvette L46 is better, because it delivered the same hp in a smaller block engine.
Now, here is my question about the L46 engine. Was the L46 limited to a manual transmission, or could it be had with an automatic as well ? Somebody here please tell me. Thanks.
Happy new year 2013 !
José, from Puerto Rico
Old Dec 28, 2012 | 10:47 PM
Dave J's Avatar
Dave J
The L46 engine was only available in 1969 and 1970. Also only available with the manual transmission.
Old Dec 28, 2012 | 10:49 PM
PeteZO6's Avatar
PeteZO6
Hola José, I'm looking at the '69 & '70 sales brochures which give the engine, trans, and final drive ratios. The L46 was only available with the four speed. You had a choice of wide ratio trans with a standard 3.36 final drive, or a close-ratio trans with a standard 3.70 final drive.
For MY '69 an optional performance ratio of 3.55 was available with the wide ratio trans, and a 4.11 could be had with the close ratio trans.
For MY '70 the only optional performance ratio was 4.11 with the close ratio trans. No optional ratio was available with the wide ratio transmission.
The L46 was only available in MY '69 & '70. No automatic was available with the L46.
The cam in the L46 was similar to the L79 327/350 and also similar to the cam in the later L82.
Pete
Old Dec 28, 2012 | 11:47 PM
1974ta's Avatar
1974ta
Default L46
Hi Jose.
I have an L46 in my 70 convertible and it runs very well.
That being said I would take an LT-1 all day long
L46 in 69 and 70 only with 4 speed. L82 cam is identical to L46. L79 is very similar but the L46 generates a little more hp and torque due to larger displacement. Remember the hp rating methodology changed from gross at the flywheel with no accessories up to 71 and went to rear wheel hp in 72 and beyond. Realistically, by todays measure, the L46 would be lucky to be rated at 300 RWHP and the LT-1 330.
Bill
Old Dec 29, 2012 | 08:28 AM
7t9l82's Avatar
7t9l82
the L-46 was a great engine. i saw them beat many LT-1 cars back in the day, mainly due to people not keeping there valves adjusted and points set properly. it came out of the gate a little better i think. while it was better the LT-1 wasn't that much better. a set of headers would make up most of the difference.
Old Dec 29, 2012 | 09:48 AM
LT-1 kid's Avatar
LT-1 kid
my two favorite engines are the L46 and the L36, both deliver good power and good low end torqe . set up with a 3:70 and they make the best street cars, however the solid lifter cars get more press, I do love the LT-1 hood.
Old Dec 29, 2012 | 10:05 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Zora Duntov once stated that the best option for the money was the L-46/L-79. He fought against deleting the option.
Old Feb 4, 2025 | 05:48 PM
Mas6ex's Avatar
Mas6ex
2nd Gear
Default L46 in '72 worth $20k?
First time poster, let me know if this should go elsewhere. Thoughts on picking up a '72 that has an L46 swapped into it? Everything else on the car works, overall great condition. Current owner has no history/didn't know it's a mismatch. Too much power for the '72 chassis, suspension, etc? Looks like they tried to make it look like an LT-1. Has the excellent LT-1 hood for example.
Old Feb 4, 2025 | 07:29 PM
Piersonpie's Avatar
Piersonpie
Welcome to the forum! 20k for any chrome bumper car is usually a pretty good deal. I would look at post #107 of this thread for overall buying advice. In general, it’s better to start a new thread if you have any questions rather than replying to one from 13 years ago.
Old Feb 7, 2025 | 07:54 PM
vettebuyer6369's Avatar
vettebuyer6369
Hi- tacking your new question onto a thread thats been dead for over 12 years will not get it seen or answered.
Please start a new thread with your question, so members can see your subject line and open it to be helpful.
To L46 350cid engine
