Hello, all body mounts removed except # 7, cage is like new, bolt is 3/4 out before it spun. Is there any way to repair it with the body on using the original cage? Thank you, Al
I don't think so. That cage and nut aren't even easy to spray penetrants on to. You might try getting as much thread lube on here as possible and then thread it back in a little. Might help lubing the threads in the nut a little. Might be enough to get it out.
Pry the cage off and put a wrench on the nut. Then find one of your non-car friends that is of good size and wrap the wrench with a towel. Then get under the car with an impact and hold the trigger until the bolt breaks or the nut is separated...
