Cam card confusion
Have to say I am leaning towards the internal balance as well, especially since it's a two bolt main block.
I hot rodded my original L-82 in stages over the years with a auto tranny. The final stage was doing 7200 rpm and doing consitant low 12's with slicks Then it croaked. I went to 383 because it took to long aquire a 396 stroker high end 3.875 42 pound crank. I still have the motor in a box as a spare I did some 11.70's and I had a 427 small block with another solid roller and changed it out
he wants to raise CR and wants to know how much more it can take.
My combo almost exactly if I were to bore .030 over and stroke it. I may have to contact him. Thanks Matt.
Ok, looked up his info and he is running a XR280HR cam. which would give it a valve closing at 70* with a 11:1 SCR that would be a 8.45 DCR at sea level and a 7.45 at altitude. So the 8.45 is not adjusted for altitude. He also has an rpm air gap intake. The cam and the air gap would allow a higher SCR over my combo. 7.45 DCR would be close to what I would have with the 377 ci combo.
and the air-gap. He is building a 400 all because the air gap killed torque on his 383. This is a common "solution" here on CF. Weak low end, then go bigger.It is speculation on my part that cam EGR helps stop pinging. Actually the reverse may be true. Or it may not matter at all with correct timing.
I actually would like the performer air gap, but would not likely fit under the hood.
The cut down divider is what butchers them, all u need is an open carb gasket if u want to try cam egr. Then u can adjust the amount, thin gasket for a little, thick for more.
BUT, as rpm's increase cam egr disappears; that is when it starts to pull hard. What do u do if it starts to ping? Reduce timing! Then it maybe runs crappy at low rpm? Reduce cam egr. Power comes back. Simple tuning.
If you build a powerful single plane motor it will have more TQ & HP at every rpm level. So forget EGR, PVC, divided plenums
I have the chassis dyno printouts. This old wives tale will never go away just like you engine needs "back-pressure", yeah your exhaust needs to be restricted to make more power, incredible
Anyhow the stroker steel crank from eagle is rated for 400HP. http://www.summitracing.com/parts/es...make/chevrolet
Anyone think I am in any danger of exceeding this HP level with 180cc Dart SHP heads, .559"lift, a roller cam and a Edelbrock performer intake not reving above 5500 rpm? This would give me an SCR of 9.84 with a DCR of 7.64 at 3000 ft?
If you have a used block you will have to overbore. I really never see a pre 86 block clean up at less than 4.020 bore. that is why the 383 (4.030 bore, 3.750 stroke) is so common.
When I closely inspected the bores just prior to deciding to do a full rebuild, instead of the top end, I notice all the bores showed a glazed surface. I don't believe this engine was properly broke in when new and the bores quickly glazed which likely gave it less compression but may also have spared it some wear over the years. Just my guess.
I can't explain how a 70's era engine could exhibit so little wear on the cylinder bores. None had a ridge except #8 which had a very stiff wrist pin and probably caused the ridge. All the pistons slid right out through the top with little resistance. Even #8 came out without much trouble. Maybe the previous owners ran it rich and changed the oil religiously, I don't know. Every bearing was in well within spec when I plasti-gauged them, more evidence of a lightly used or well cared for engine.
Here is a pic of the bores before and after.
[IMG]
[/IMG]Last edited by REELAV8R; Jan 6, 2013 at 01:06 PM.
My combo works so well, i cancelled plans, in 1999, for a 383. Not lacking power in any respect for street use.
They should have the same respect for a strong 355 that i have for larger sorted out engines. My combo is a low budget build, $850 in 1999($1200-1400 upgrade today), it is hard to beat this much fun for so little money. ~385 HP was 200 stock.
i agree Scat crank gets great reviews. how much more is it?
http://www.summitracing.com/search/m...t%20crankshaft
That's a $354 difference.
this is much more reasonable.
http://www.summitracing.com/parts/sc...make/chevrolet
Kind of makes a big deal about it being lightweight, is this going to be a problem with balancing it?
http://www.summitracing.com/parts/sca-935010
http://www.summitracing.com/parts/sca-2570020
http://www.summitracing.com/parts/uem-kb135-std
These pistons give me the previously mentioned CR's.
It'll be $200 just to balance the whole works
Can't find a internally balanced assembly with 18cc pistons.
