Engine guys. Your thoughts on this engine rebuild
Here's what I get from the engine numbers.
Engine casting 3932386 (350-350 early L-46)
Pad# V0927HW (Flint Engine, Sept 27, 1969 Hi-Perf Manual)
Bores to .040 oversize, 6 inch long connecting rods, 9:1 compression, hyperutectic pistons, and new iron heads. Parts to be used would be;
Clevite 77 rod and main bearings
Durabound cam bearings
Keith Black #KB112 +.040 pistons
Moly face performance rings
Eagle SIR6000BBLW rods with bushed small end
Dart Iron Eagle heads with 180cc intake runners, 72cc chambers, 2.02 intake valves, 1.600 exaust valves
Melling M55HV hi volume oil pump
Engine Pro double roller timing chain and gear set, with locking bolt retainer
Hydralic lifter camshaft with 214 deg Intake duration, 224 deg exaust duration, .443 int. lift, .465 ext lift
Brass freeze plugs
Thanks,
Mike
So i'd ask him "how much more for a 3.75 stroker crank"
if the price is right, go 3.08 rear.
Brass freeze plugs
Thanks,
Mike
Also, why bother with 6" rods - you'll have better torque at low-to-mid range rpm with the stock rods (5.7") which give a nice 1.64 rod-to-stroke ratio.
I'd vote for Speed Pro hypereutectic pistons too since I'm not a fan of the large top ring gap with the KB pistons:
Last edited by larrywalk; Jan 4, 2013 at 02:21 PM. Reason: Edited sentence structure for better clarity.
I read u want to keep the forged 350 crank so that leaves u with less than 360 c.i.. With those highway gears i think u should stay with less than 270 degrees full duration cam - which is close to what u listed but try a 108 or 110 lobe separation angle for optimum power. No need for 6" rods - they make power at higher rpm - higher than what your cam will run at. Sorry i don't know a thing 'bout Iron Eagle heads but read they are getting very popular. Everything else reads good to go.BTW i still have my original 3.23 GM gear set in the box covered with grease. Let me know if your intersted, but shipping to michigan may not be cheap.
Good luck,
cardo0
