IM SO HAPPY!!!!
Old Jun 11, 2002 | 03:55 PM
ykp53's Avatar
ykp53
Default IM SO HAPPY!!!!
I FINALY HAVE A/C. I ordered my first part 360 days ago, and today I picked it up from the shop that filled it for me. in the end it only cost me about $600 to install everthing (except the evaporator. ) i tell you the thing gets cold. it may squel like a stuck pig, (the belt is a littlle loose) but its cold. The shop put 3.5 lbs of r-134 a in it. i thought that it would need less than that.? anyone know for sure? :D :D :D
Old Jun 11, 2002 | 04:01 PM
luvmy82's Avatar
luvmy82
St. Jude Donor '12
Default Re: IM SO HAPPY!!!! (ykp53)
Lucky you...I wish I had the same happy ending. Had the '82 converted to R134a, all parts are new and fuctional, had the system vacuumed and new refrigerant added with stop leak, and 3 weeks later, just as warm as the air outside.
Dye was added to spot any leaks before recharging and zip, nothing.
What the hell is going on???? Why don't I have cold air blowing?
Old Jun 11, 2002 | 04:13 PM
FeedVaal's Avatar
FeedVaal
My 77 is supposed to hold 46oz that's 2.87 pounds of r12. Since r134a works at higher pressures the capacity is usually 80% of r12 charge. You may be squealing do to a severe overcharge of the system. You need to get some gauges on there and find out what your pressures are.
luvmy82, I,ve been trying to chase a leak in my wife's accord with UV dye without success. I've read that the stop leak stuff is worthless for anything other than a pinhole sized leak. That's proved to be the case for me so far.
[Modified by FeedVaal, 4:17 PM 6/11/2002]
Old Jun 11, 2002 | 04:16 PM
Fevre's Avatar
Fevre
[URL}http://forums.corvetteforum.com/zerothread?id=319232 [/URL]
Read this post.
To IM SO HAPPY!!!!
