L31R replacement engine?
Old Jan 4, 2013 | 06:07 PM
Zorro O's Avatar
Zorro O
Default L31R replacement engine?
I have a 1979 C3 that until recently had an L98 with a 700R4 in it. The motor is gone. I still have a 700R4 trans, and all the stuff that bolts to the motor including a TPI setup that I like very much. I have been looking at crate motors, but have had trouble finding what I would like, (a 350 with at least 250hp, a roller cam, and be compatible with the TPI). What I am wondering is, would this motor, the way it comes LINK with the right base plate for my TPI, be appropriate? My objective is reliability, decent power (250+), decent millage (20+Hy), total expense under $3000.00.
Thanks for looking.
Zorro
Old Jan 4, 2013 | 06:42 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Great option but it needs a cam upgrade horribly.
Old Jan 4, 2013 | 06:58 PM
drwet's Avatar
drwet
This might be a nice little motor with an L-82 cam in it, but a stock TPI isn't enough to feed it.
Old Jan 4, 2013 | 07:30 PM
hwcoop's Avatar
hwcoop
good selection here
http://www.jegs.com/s/GM_Engines/GME...eshipping.html
Old Jan 4, 2013 | 08:14 PM
Zorro O's Avatar
Zorro O
Can you tell me how, the cam it (L31R) comes with, will affect the drivability of the car? 1979 C3 700R4 auto, 3:55 rear end gears.
Thanks.
Zorro
Old Jan 4, 2013 | 08:41 PM
drwet's Avatar
drwet
Thanks.
Zorro
It will be very driveable, but it will be a bit of a dog. You won't have much over about 4000 rpm and the TPI won't help.
Old Jan 4, 2013 | 08:57 PM
Zorro O's Avatar
Zorro O
Sounds like you are describing my L98. I know the TPI is not great for power (under statement) But it is so easy to live with, work on, and paid for!
Zorrio
Old Jan 4, 2013 | 09:21 PM
drwet's Avatar
drwet
Zorrio
Ya gotta love paid for!
The cam in the crate motor is probably a pretty good match for the TPI. Lots of bottom end but will run out of steam pretty quick. Not what most of us are looking for when we build a Corvette motor, but it will work. If you decide later that you want to wake it up a bit, add more cam, a good four barrel and manifold, and a set of headers and you'll have a nice little motor.
Old Jan 4, 2013 | 10:12 PM
7t9l82's Avatar
7t9l82
your gas mileage should be reasonably good, you can make improvements on the t.p.i anytime
Old Jan 6, 2013 | 11:20 PM
Zorro O's Avatar
Zorro O
What cam would you recommend? Keeping in mind it will have the TPI. I hate the idea of pulling apart a brand new motor. But I might get over that, with I right in front of me.
Zorro
Old Jan 6, 2013 | 11:31 PM
drwet's Avatar
drwet
Personally I like the L-82 cam (GM PN 3896962). There are about a hundred aftermarket cams with similar numbers available from the aftermarket cam companies. (222 deg duration at .050" .450 lift) If you think there is any merit in the argument that modern lobe design offers an advantage, then pick your favorite company and pick a cam sith similar numbers. If you are going to stick with stock exhaust, you will probably want to pick a cam with a little more exhaust duration.
The problem for you is that your TPI isn't nearly enough to feed an engine with this cam. That TPI system was designed for the 305 and just won't let a 350 beathe beyond about 4000 rpm. A cam with the numbers I have quoted comes alive at 3000 rpm and up. That would be a bad combination. If you use the TPI, keep the cam you have. If you want more cam, you need a better induction setup.
Old Jan 7, 2013 | 12:06 AM
63mako's Avatar
63mako
http://www.summitracing.com/parts/cr...make/chevrolet
http://www.summitracing.com/parts/cr...et?prefilter=1
Made for TPI, works with vortec lift, factory roller cam, computer compatable, Match your OD auto trans. Would love a 2200-2400 stall
Learning_Curve's Avatar
Learning_Curve
What is the weak link in the TPI setup? To even use the TPI with the Vortec heads he is going to need an aftermarket lower manifold which should flow more than stock.
Here's an article on the Scroggin-Dickey manifold, where they got over 300 horses with stock runners and throttle body and L98 cam.
http://www.gmhightechperformance.com...d/viewall.html
High flow runners and a bigger throttle body could be added later.
He can't use the L88 cam as this motor uses roller lifters. A stock LT1 cam could be got secondhand for cheap, and adds about 10 degrees of duration. I'm not sure if they have too much lift for the valvesprings though. Anything bigger is going to take expensive beehive springs.
Old Jan 7, 2013 | 11:41 AM
63mako's Avatar
63mako
The LT4 hot cam is typical upgrade but the lift won't work without signifigant work on the heads and or springs. The cam I linked is similar in manners but limited lift for stock vortec heads. The above article is helpful. Bet the vortec aftermarket intake flows better than the factory setup. Pretty impressive numbers.
To L31R replacement engine?
