73 Front Bumper installation
Old Jan 6, 2013 | 09:47 AM
sjmcdowell's Avatar
sjmcdowell
Default 73 Front Bumper installation
I am trying to re-install my 73's front bumper (the metal bar).
Does anyone have drawings or something with measurements?
I have to assume that some point is the bench mark from which you start.
If you look at the assembly manual UPC 14A sheet 1, I don't understand the "bolt unit #3" and how it goes trough the slider brkt and holds on the fender support.???
Also UPC14 sheet 2 ; When I attach the bumper at each end to the brace assembly I am left with 3/4" gap between the bumper and the slider brkt. Do I fill this with shims? hence back to the drawings....
If someone had a good picture it would be worth a thousand words.
Thanx
Sam
Old Jan 6, 2013 | 10:48 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by sjmcdowell
...If you look at the assembly manual UPC 14A sheet 1, I don't understand the "bolt unit #3" and how it goes trough the slider brkt and holds on the fender support.?...
My 74 AIM references UPC 11A Sheet 2 for the support which the bolt unit attaches to. My hunch is that 73 and 74 are the same.
...Also UPC14 sheet 2 ; When I attach the bumper at each end to the brace assembly I am left with 3/4" gap between the bumper and the slider brkt. Do I fill this with shims?...
You should be able to move the braces forward. My 74 AIM shows shims only between the crash bar and the frame extension.
