BB sometimes diesels at shutdown
Old Jun 12, 2002 | 12:15 AM
hudman's Avatar
hudman
Default BB sometimes diesels at shutdown
About every third time, my '68 427 diesels for a few seconds after shut off. Nothing horrible, it may turn over just a few times and then dies.
What causes this?
Old Jun 12, 2002 | 12:33 AM
RatRacer's Avatar
RatRacer
Default Re: BB sometimes diesels at shutdown (hudman)
High idle and low octane fuel are the usual suspects.
Old Jun 12, 2002 | 02:35 AM
jdunne's Avatar
jdunne
If it is an auto,turning the key off in gear before you put it in neutral or park will solve the effect but not the cause...john :chevy
Old Jun 12, 2002 | 11:57 AM
Turbo-Jet's Avatar
Turbo-Jet
idling too lean maybe?
Old Jun 12, 2002 | 03:36 PM
69 N.O.X. RATT's Avatar
69 N.O.X. RATT
From: Pettis Performance 565 with two stages of Nitrous Supply nitrous 1.082, 4.61 at 155, 7.17 at 192
Default Re: BB sometimes diesels at shutdown (Turbo-Jet)
High performance, high compression motors on the verge of detonation due to poor gas will do this all the time. If you are not detonationg it is not a big deal, when it is dieseling the motor is actualy turning backwards. I have a 454 that does this on hot days and it sounds terrible and is embarrasing at shows and stuff. If you have a manual transmission put the car in third gear and let off the cluch untill the rpms start to drop, then turn off the ignition, it will shut off immedialty. :chevy
Old Jun 12, 2002 | 03:40 PM
Fevre's Avatar
Fevre
Default Re: BB sometimes diesels at shutdown (69 N.O.X. RATT)
I have also heard tales of running too hot a plug causing this. Not sure if it is true but thought I would throw it out there. If wive's tale, please correct me.
Old Jun 12, 2002 | 04:04 PM
MasterDave's Avatar
MasterDave
Moderator
A mis-adjusted carb, the primarys or secondarys open a little too far at idle will suck air/fuel when shut down and cause this, especially on a hot engine.
Old Jun 12, 2002 | 06:09 PM
Wrencher's Avatar
Wrencher
I'll assume that it's a Q-jet. You can add an A/C solenoid, again assuming it doesn't have air, to set the base idle. Then back off the idle stop 'till the throttle plates are closed (so it won't idle with the solenoid off). These came on a bunch of later model carbs and you should be able to find one with the mounting bracket. It works especially well on auto trans equipped cars. Hope this helps.
Hans
Old Jun 12, 2002 | 06:54 PM
bence13_33's Avatar
bence13_33
You also need to watch your timing, too much advance will also contribute to this effect.
Old Jun 13, 2002 | 12:34 AM
hudman's Avatar
hudman
Wow-
You guys really nailed this one. I have all of the above problems.
First of all, for those of you that have not seen my recent posts, the car is new to me (1 week).
Lets see. . .
I have an idle problem. Car idles fine at cold start up. Choke engages and car idles at 1300-1500. Tap accelerator and idles settles down at 700-800. After driving the car fully warmed up, idle will not settle down to 700-800 range again. It stays in the 1200 range. Very annoying. This was my guess for the problem. What puzzles me is that the carb is new. Any ideas?
Timing is advanced and car should be running higher octane fuel. Previous owner mixed in leaded 110 racing gas with unleaded premium. Without it he got a lot of spark knocking. I have located 100 octane fuel locally but have not gotten the mixture right. Under heavy acceleration, I noticed some spark knocking tonight. I guess I need more of the expensive stuff.
Obviously, it has been hotter than hell around here and combined with the above, I think I have my problem diagnosed.
Thanks for the suggestions. I will work on the correcting them.
Old Jun 13, 2002 | 01:50 AM
69 N.O.X. RATT
Regarding the idle problem, could be as simple as neading the idle adjustment screw adjusted. Let the car get warmed up and adjust your idle to were it should be. The fact the carb is new had nothing to do with it needing an adjustment.
Do you know the compression of the motor, if not find out. You may be able to burn lower octane fuel if you do not havce to high of compression. You do not want the car detonationg, destroys engine fast if it is bad enough. :chevy
Old Jun 13, 2002 | 01:33 PM
Lohkay's Avatar
Lohkay
I had this kind of idle problem before...it was the eletric choke. But since your carb is new, I dunno.
Old Jun 14, 2002 | 12:14 PM
fontking1a's Avatar
fontking1a
With my '69 4 speed I put one foot on the brake, put the car into third gear and slowly let my foot off the clutch. When the engine rpm drops...I turn the key off. This ritual has been going on since the 70's. We're victims of high compression, crappy gas and a world that isn't much interested in BB cars anymore. This method works well for me. I also use plugs that are gapped .010 over and this seems to reduce ping and hasn't hurt anything in the engine so far. Also, Tribotech in the crankcase every 60,000 miles seems to help. The engine has never been out of the car and is approaching 180,000 miles and still runs like a champ. Those morons driving $100,000 Porsches wonder why they spent so much money to get their doors blown off by a 30 something year old car. Ain't life great?
Old Jun 14, 2002 | 01:59 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
What causes this?
bad gas!
The 327 in my 68' only has 9.5:1 compression but if I use 92 octane instead of 93 it sometimes diesels... Avoid SPEEDWAY 92 octane gas!!!
:cheers:
Olivier
To BB sometimes diesels at shutdown
