another dyno story
Old Jan 11, 2013 | 06:34 PM
1977L48's Avatar
1977L48
Default another dyno story
ok so after more tuning and a new timing chain my L48 with edelbrock q-jet intake, headers, street fire dizzy with accel super coil and curve kit put down 205HP at 4400rpm and 266tq at 3000rpm. it was done on a dynojet, weather conditions were 74 degrees and 42% humidity. i also had my timing at 12degrees BTDC and was running 89 octain gas.
Old Jan 11, 2013 | 06:42 PM
johnt365's Avatar
johnt365
What transmission do you have?
Old Jan 11, 2013 | 06:43 PM
1977L48's Avatar
1977L48
TH350 with 3.08 rearend gears
Old Jan 11, 2013 | 06:45 PM
1977L48's Avatar
1977L48
A/F ratio was 13.22, not perfect but i can live with it. im still running the q-jet, just rebuilt it
Old Jan 11, 2013 | 07:13 PM
jb78L-82's Avatar
jb78L-82
I did 233 RWHP @ 5,500 and 273 RWTQ @ 3,500 RPM with a stock L-82 with Shorty headers, 2.5 inch duals, Holley 4175 650 CFM Q-Jet replacement, OEM aluminum L-82 intake, and Comp Cams roller tipped 1.5 rockers with a #6 weak cylinder. I figure that the L-82 in my car is good for 240-245 RWHP with all cylinders functioning correctly. Your numbers are pretty much what I would expect from a mildly breathed on L-48, about 40 RWHP less HP than the L-82. Looks like you have it dialed in pretty good since those are about the best numbers you could hope for. Good job!
Old Jan 11, 2013 | 07:35 PM
bluedawg's Avatar
bluedawg
Larger cam and a set of good heads would bump ya up quite a bit. When i dynoed my l48 12.8 or so seemed to make the most power.
Old Jan 11, 2013 | 07:38 PM
jb78L-82's Avatar
jb78L-82
That's what i am planning to do soon to my L-82: AFR 180 65CC heads and Howard's Roller cam (not quite set on which one yet)-no other changes. Hoping for 325 RWHP!
Old Jan 11, 2013 | 07:42 PM
bluedawg's Avatar
bluedawg
Shhould put ya close.
Old Jan 12, 2013 | 12:11 AM
PaPaPork's Avatar
PaPaPork
for stock heads and trans this is a good number for RWHP! Good luck with your goal!
Old Jan 12, 2013 | 10:57 AM
1977L48's Avatar
1977L48
And stock baby cam
Old Jan 12, 2013 | 03:02 PM
bluedawg's Avatar
bluedawg
Thats almost stock. the 77 and 76 put out 180 hp I beleave net. I'm not for sure what year they went from gross to net, none the less thats somewere in the neighbor hood of 40 to 50 horse from intake, headers & tune. Impressive. You hear it on here all the time that headers and tune are the cheapest bang for the buck, proven here by your numbers.
Old Jan 12, 2013 | 03:12 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
That's impressive for a near stock L48. I had heads cam intake carb headers 10:CR and missed the 300RWHP mark, made 296RWHP and 330 RWT.
It was still a great motor and a lot of fun but not as easy as it sounds to make 300HP at the wheels with 350ci and flat tappet cams. Consider the losses you need to be making 400HP or more at the flywheel with a TH350. Now roller cam might have made a difference but at the time there was no street rollers.
Old Jan 12, 2013 | 04:01 PM
bluedawg's Avatar
bluedawg
When you dynoed the 406 and figured your losses @ 22% what transmission was that through? When I dynoed the l48 the guy running the dyno said that the losses differed with each transmission.
Old Jan 12, 2013 | 04:16 PM
1977L48's Avatar
1977L48
It was 1972 when they switched the ratings
Old Jan 12, 2013 | 05:54 PM
johnt365's Avatar
johnt365
I thought the same thing, nothing left on the table.
You know, with all the NCRS guys on this forum I am surprised we don't have a true "stock" chassis dyno baseline for these cars. THAT would be a great sticky. Bone stock L48 through a TH400 and 3.08 = ? etc...
To do that though we would have to find an NCRS guy that would rev his car to 5k. Is that allowed?
Old Jan 12, 2013 | 06:08 PM
1977L48's Avatar
1977L48
That would b awesome, but every engine is going to perform differently. A monday or friday built engine will IMHO will make less power than a tuesday wednesday thursday engine.
Old Jan 12, 2013 | 06:40 PM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
...not to mention the temperature and elevation at which the test was conducted - gotta be corrected to standard conditions first!
To another dyno story
Old Jan 12, 2013 | 07:51 PM
iokepakai's Avatar
iokepakai
Going to a roller cam soon here's what I found out,Howards Cams are not ground on a billet core!! Got this reply from them:
That cam is ground on a SADI cast core & requires no special distributor gear.
THANX
John Steely
HOWARDS CAMS
Phone 920-233-5228
Fax 920-233-0938
Good going on the dyno run. Looks like you got it tuned pretty well...
Old Jan 12, 2013 | 08:21 PM
bluedawg's Avatar
bluedawg
THANX
John Steely
HOWARDS CAMS
Phone 920-233-5228
Fax 920-233-0938
hydraulic or solid roller? Not for sure what sadi is.
Old Jan 12, 2013 | 09:18 PM
DRIVESHAFT's Avatar
DRIVESHAFT
Selectively Austempered Ductile Iron
