Lets talk Paint
Old Jan 13, 2013 | 02:43 PM
77SOAR(A)'s Avatar
77SOAR(A)
Cruising
Default Lets talk Paint
Like most every one else out there i almost in over my head on a restoration. At the moment i have a very heavily corroded 77 that exploded all over my garage.
On most parts it is just surface rust so i have been slowly cleaning it all off with wire brushes and wire wheels for the drill. What is the best paint to use these parts once they are cleaned off to prevent this from happening in the future? The parts i am going to be painting will range from random brackets to the whole chassis.
Thanks.
Old Jan 13, 2013 | 03:28 PM
oledave60's Avatar
oledave60
There is a ton of options from $ to $$$$, but I am on a limited budget and in way too deep. I used Rust-oleum on just about everything except the motor.
Old Jan 13, 2013 | 03:31 PM
birdsmith's Avatar
birdsmith
The BEST paint in a general sense would be the sort that you spray out of a paint gun rather than rattle-can type. If you don't want to go through the hassle of hooking up paint guns, etc. though I would avoid enamel-based paints as they are not compatible with anything else. You can shoot enamel over lacquer primers but not vice versa, so I would avoid things like Rustoleum. SEM makes a number of high quality spray can paints, but polyurethane-based catalyzed products of the sort that you buy from an automotive paint vendor and shoot from a paint gun are by far better than any rattle-can products.
Old Jan 13, 2013 | 03:59 PM
oledave60's Avatar
oledave60
I didnt use rattle can paint, but brush on from a quart can so I could get a thicker coat. I am confused as to why I need to worry about compatibilty when everything is painted with the same paint.
Old Jan 13, 2013 | 04:00 PM
Doug1's Avatar
Doug1
my first inclination is rustoleum rattle cans. but after thinking about total volume needed to spray an entire frame, I'm with birdsmith (automotive finish shop)on this one. this is assuming you have compressor and spray gun. If you need to get a spray gun, harbor freight cheapie will be more then good enough for a frame
Old Jan 13, 2013 | 04:01 PM
Doug1's Avatar
Doug1
Originally Posted by oledave60
I didnt use rattle can paint, but brush on from a quart can so I could get a thicker coat. ..
that works too
Old Jan 13, 2013 | 04:36 PM
hwcoop's Avatar
hwcoop
I sandblasted everything then gave 2 coats DP90 Epoxy primer followed by a couple of finish coats of satin black, or cast grey depending on the component. Finished up by oil spraying inside my frame rails and crossmembers.
Old Jan 13, 2013 | 05:42 PM
qwank's Avatar
qwank
Great looking frame. I'm so sick of seeing gloss black, your's looks awesome
Old Jan 13, 2013 | 05:57 PM
oledave60's Avatar
oledave60
Thanks, It's satin.
Old Jan 13, 2013 | 06:17 PM
birdsmith's Avatar
birdsmith
Oledave, sorry if that came out looking like I was 'stepping on' what you posted. I was actually typing mine at the same time you were typing yours, so it wasn't intentional. Rustoleum IS quality stuff, but there is the little incompatibility thing, and I have also noticed that gas eats right through it...fine for lawn furniture but not so good for a car. Your car DOES look good, BTW!
Old Jan 13, 2013 | 08:11 PM
MIKE80's Avatar
MIKE80
Most people use POR 15. That's what I used on my birdcage. The chassis was acid dipped and powdercoated. The suspension, cossmembers, rad. support were all also powdercoated. If you use POR 15, topcoat any areas that will get sunlight, it has no UV protection.
Old Jan 13, 2013 | 08:19 PM
oledave60's Avatar
oledave60
As I said this runs from $ to $$$$. Mine is $ and this one is $$$$. Great looking frame and wish mine looked the same. Dave
Old Jan 13, 2013 | 08:56 PM
MIKE80's Avatar
MIKE80
Thanks. Yours looks good too. Nice job on it. The cost for the rad. support, frame, trans and fuel tank crossmembers for acid dip and powdercoating was $900.
Old Jan 13, 2013 | 09:27 PM
GT's 78's Avatar
GT's 78
Took mine to someone. Didn't have the equipment to do it. Had mine sand blasted inside and out, epoxy primer and paint inside and out.
Old Jan 13, 2013 | 09:53 PM
oledave60's Avatar
oledave60
I think I will delete my picture. You guys are too good.
Old Jan 13, 2013 | 10:34 PM
77SOAR(A)'s Avatar
77SOAR(A)
Cruising
Thank you for all the advice.
I do have a sprayer and a home made booth (tarp and PVC tent i have been using for sand blasting. I have heard a lot abought the POR 15 and all of it has been good. Will probably end up doing the frame with a higher quality paint like the POR 15 and a lot of the little stuff with a cheaper rustoleum just to keep cost down.
On a side note I do like the look of the satin finish better but wouldn't the be harder to keep clean than the gloss? Haven't done much with metal paint just thinking of house paint, satin is always harder to keep clean than gloss. I am by no means going to have a show car and not a daily driver just want it to stay clean since I'm going to have a couple of years of work into it.
Old Jan 14, 2013 | 08:45 AM
jmp's Avatar
jmp
The hell you will, looks good! Shows a lot of work too!
Old Jan 14, 2013 | 10:45 AM
7t9l82's Avatar
7t9l82
por-15 is tough to beat, even brushed on it looks good
To Lets talk Paint
