Most major problems only reques minor solutions
Not being an HVAC expert, but good at replacing parts until I eliminated all possibilities that would cause the problem, I chose a more sensible solution and sought the advice of a professional. My choice, Mr. Artic Air, did a partial charge (wanted to save the gas in case their was leaks in the 30 year old system). This action initiated the low pressure switch (good) and allowed the compressor clutch to engage (great). All seemed to go well with the exception of warm air blowing on my feet and no air coming from the upper vents (not good). Right away Mr. Artic Air unceremoniously declared I had a vacuum leak and that the dash would have to come out for him to adequately trace the tubing down to find the problem…at the hourly rate of $75. But don't worry, "I have been doing this type of work for 40 years."
Wait a minute! Hold up! Let’s remove the glove box and look in their first and see if we can identify any problems first before removing that dash. I know I am the novice here, but I am not a gullible dumb *** either. I must confess I am the one who looks for the simple solutions first. Past experience has taught me (at cost) to analyze the problem from all angles, identify what components make up the system, determine how they are linked and then deduce what could cause the existing condition; in this case, hot air cooking my feet. Mr. Artic Air didn’t want to hear theory, he just wanted to tear down and replace with new (which would have worked…but, as it turns out, was not necessary) at a tidy profit. Not wanting to **** off Mr. Artic Air (I did need his R-12, which as you may no is somewhat hard to obtain); I said I would return in a few days with either the vacuum problem fixed or the dash removed so he could trace vacuum issues and make necessary corrections.
I missed something in the previous paragraph I need to mention. I, the unskilled HVAC man, noticed the bypass valve vacuum switch was not being controlled by the flapper control lever due to maladjustment. I had reason to believe that nothing else had been changed in the original system and all the vacuum tubing (at least inside the cab) was in very good condition with color coding still etched on the tubing. Returning home and cranking up the old 'puter I began a research on automotive HVAC systems. By the end of my “training” I was convinced that the bypass valve vacuum switch was the weak link (it is the only component made out of plastic). Readjusting the cable adjusting turnbuckle so that the plunger was seated inside the vacuum switch casing (where the lever was pulled all the way to the left (cold) on the climate control module), I started the engine, flipped on the A/C MAX and turned on the blower to high. After a minute, the upper vents opened up and cool fresh air entered the cabin (and some aged dust full of carcinogens). I still must return to Mr. Artic Air to recharge the system to full and I will still be monitoring for possible leaks, but, for all practical purposes, the HVAC is operational. I still have the rest of winter to test for reliability of the system. I live in Florida and it gets hot. Even with the T-tops off you still need to have the A/C on if you want to stay cool and comfortable.
In the picture below you can see the flapper control lever (rusty metal) making contact with the bypass valve vacuum switch (yellow plastic) and this is viewed through through the glove box opening. It is a tight fit, but doable.
P.S. The cost was zero dollars to repair system. The Freon will run me about $50-75 depending on how Mr. Artic Air, guardian of the R-12 gas, feels that day. Moral of the story is to read the schematics and pick the weak link in the system first, then move on.
Last edited by scorpion18z; Jan 14, 2013 at 06:19 PM. Reason: Grammar and punctuation
That vacuum switch controls the hot water from the engine to the ventilation system. If that button is not depressed it will have a continuous flow of hot water going to the ventilation system.
