Tranny leaking
Old Jan 16, 2013 | 06:18 PM
Firebird77's Avatar
Firebird77
Default Tranny leaking
Hello guys,
I just purchased my first '73 Vette. The car is clean and allover tech state seems fine but there seems to be tranny leaking a bit. As I'm new to the Vette tech stuff, can you please check and advise how difficult is to solve this? Thank you.
...and here's the point where a picture needs to be inserted, unfortunately not sure how to paste it from a local disk - can anyone advise please?
Old Jan 16, 2013 | 06:48 PM
my 76 ray's Avatar
my 76 ray
There is a sticky thread at the top of the C3 General forum that explains how to post pictures.
Old Jan 16, 2013 | 07:38 PM
Firebird77's Avatar
Firebird77
Originally Posted by Firebird77
Hello guys,
Here it is... (thanks to 'my 76 ray')
Old Jan 16, 2013 | 07:39 PM
garygnu's Avatar
garygnu
is it wet buy the flex plate cover ?mite be leaking where the gear shaft goes into the trans casing.if the car sits long enough ,fluid from the converter can drain into the pan raising the fluid level in the pan to the height of the gear select shaft.
Old Jan 16, 2013 | 07:44 PM
Oldguard 7's Avatar
Oldguard 7
Originally Posted by garygnu
where is it leaking from ?
My guess shifter shaft seal.
Old Jan 16, 2013 | 07:54 PM
Firebird77's Avatar
Firebird77
The car was sitting long indeed - for over 2 months now. I will be checking the fluid level for sure, but do I think right that if this is the case (and most probably is), the leaking will stop at some point and the fluid level should still be OK? Or I still need to replace the gear shaft seal?
Old Jan 16, 2013 | 08:04 PM
johnt365's Avatar
johnt365
Are you positive it is transmission fluid? Trans fluid is red (ideally) From the photo its hard to tell if that is trans fluid or motor oil. Look at your white oil filter in that photo. Is that black dot a drop of oil? If yes, then it could be that as you drive the motor oil is dripping and blowing back and misting that part of the transmission.
Just a thought. might be way wrong but leaks can be deceiving.
Old Jan 16, 2013 | 08:08 PM
bluedawg's Avatar
bluedawg
when you look at the picture the oil filter looks to have a drop of oil on the bottom. could be from when it was installed that the installer didn't take time to wipe it off or the seal on the oil filter is dried up and needs to be replaced. I use grease on the rubber seal when I install an oil filter it won't dry out. Were I was going with this is the shifter cable seems to be in line with the filter, when you put a white rag to the wet spot is it red or brown.
Old Jan 16, 2013 | 08:09 PM
Firebird77's Avatar
Firebird77
I noticed the drop on the oil filter too, it's not the case as this drops only very little. And the major leak fluid is red (almost orange).
Old Jan 16, 2013 | 08:23 PM
johnt365's Avatar
johnt365
Your transmission is so clean it looks new. This should help you chase down the origin of the leak.
Old Jan 16, 2013 | 09:14 PM
Mooser's Avatar
Mooser
Wash everything down real good and wait for it.
That book on the shifter cable will hold a surprising amount of fluid and slowly leak it out also.
The seal on the shifter shaft can be replaced from the outside. There is a tool that pulls the old seal out without damaging (scratching) the shaft.
Check around (google) there should be tons of pages on replacing the seal on a TH400.
Mooser
Here's one right on our forum
http://forums.corvetteforum.com/c3-t...r-linkage.html
Old Jan 16, 2013 | 09:25 PM
Firebird77's Avatar
Firebird77
Thanks guys for your ideas, will get my hands on it asap .
Old Jan 17, 2013 | 08:16 AM
Vette5.5's Avatar
Vette5.5
Your best bet, is probably putting some UV trace dye in both the engine crankcase and the tranny fluid. You can get the the dye that shows up different colors under the UV trace light. Maybe green for the engine, and orange for the tranny. Also, sometimes when an auto tranny filter plugs, fluid can blow out the vent tube. Had this happen before, and changing out to a good quality name brand filter, solved it.
Old May 23, 2013 | 05:12 AM
Firebird77's Avatar
Firebird77
Default Tranny leaking - update
Hello guys, after a while I'm back with a little update. Finally I was able to trace the spot from where the trans. fluid was leaking. Can you please check the photo and advise what is needed to fix this? The main leak is at point nr. 1. There are some drops also at point nr. 2 (not sure how those could get there). Thank you.
Old May 23, 2013 | 07:14 AM
Mooser's Avatar
Mooser
The speedometer gear seal is fairly straightforward
Try to park with the nose of the car downward so you don't loose too much fluid.
There is a seal and an o-ring. Here's some reference info with a pic of the seal
http://forums.corvetteforum.com/c3-t...edo-cable.html
Frequently they install 2 seals instead of 1, I've done it a few times and it works fine.
Mooser
Old May 23, 2013 | 10:37 AM
Firebird77's Avatar
Firebird77
Greatly appreciate your help on this Mooser. Thank you!
Old May 23, 2013 | 11:38 AM
my 76 ray's Avatar
my 76 ray
I was able to get a seal at a transmission shop. The Chevy dealer couldn't find one.
To Tranny leaking
