Taking baseline engine readings - prepping for topend refresh
Old Jan 19, 2013 | 03:16 PM
TedH's Avatar
TedH
Default Taking baseline engine readings - prepping for topend refresh
@ Idle:
65-70psi (hi volume)
800rpm
36 degrees timing
Is my timing too far advanced at idle? Runs like a scalded dog. That is with distributor vacuum line plugged or connected.
Old Jan 22, 2013 | 02:57 PM
MelWff's Avatar
MelWff
You should not have 36 degees at idle with vacuum disconnected. Are you sure timing light is connected to number 1? Is this a dial back timing light?
