Head light question
Old Jan 20, 2013 | 03:59 PM
Belgian1979vette's Avatar
Belgian1979vette
Default Head light question
I just put in my rebuilt steering column and attached all the wiring. The headlight however do not go up or down when using the headlight switch. I can get them to open and close with the override vacuumswitch.
Hoses seem fine and are new.
What could be causing this ?
Old Jan 20, 2013 | 08:30 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The over-ride switch is the next switch in the system between the headlamp switch and the relay.. So I'm going to guess you have a switch problem. For the over-ride to work it has to be getting vacuum and blocking it. For the over-ride to get vacuum the hoses have to be attached to the headlamp switch.
So this makes sense.. The vacuum is pulled from the check valve at J located on the hose diagram below. The vacuum pass’s through J to hose H by going in and out of the headlamp switch. The headlamp switch blocks the vacuum which makes the lamps come open. So as you can see from the diagram for vacuum to make it to the over-ride it has to be passing through the switch which is what leads me to conclude the switch is bad.
A quick test would be for you to pinch the hose J closed… at the firewall… if this makes the lamps open, (I feel sure it will) then the only thing between those two points is the headlamps switch.
Old Jan 21, 2013 | 04:22 AM
Belgian1979vette
Thanks, I was thinking that maybe I switched the hoses going to the switch in the wrong position (reversed) which would have made it necessary to take the cluster out (again).
I will pinch the line and see if something moves.
BTW : how do you get the know of the headlight switch to disassemble the switch from the dash. I remember not getting it out ...
Old Jan 21, 2013 | 06:04 PM
Belgian1979vette
I first reversed the hoses at the headlight switch and that solved the problem. So far so good, but the dash light seem not to be working.
Any ideas on that ?
Old Jan 21, 2013 | 06:20 PM
worship79's Avatar
worship79
Have you tried turning the **** on your headlight switch?
If so; have you removed one of the clusters? Perhaps one of the copper 'fingers' on the circuit board where the plug uhm, plugs in (lol) is askew or even touching one of the other leads. Had that myself recently.
Old Jan 21, 2013 | 06:23 PM
CiCiC3's Avatar
CiCiC3
There's a toggle type switch on the lower dash by the steering column that sometimes gets bumped and shuts off headlight operation. hate that when that happens. (just an idea)
Old Jan 22, 2013 | 01:45 AM
Belgian1979vette
? I have never seen a switch there ? Do you have a picture ?
Old Jan 22, 2013 | 01:46 AM
Belgian1979vette
Yes, will have to check that one. The odd thing is the center gauge cluster doesn't have lights either.
Old Jan 22, 2013 | 07:51 PM
CiCiC3's Avatar
CiCiC3
Yes it is pictured in the drawing that someone posted near the top of this thread and it is at the very top labeled D.
I have one on my 74 that looks just like that in black near the steer col. Im not sure if the 79 has it like that but suspect it does.
It just turns off the headlight hydrolic retract and disables it. Flip to toggle on again.
Old Jan 22, 2013 | 07:55 PM
0Willcox Corvette
Former Vendor
http://willcoxcorvette.com/product_i...ducts_id=24359
To Head light question
