My 4 speed is a 2 speed...
Old Jun 12, 2002 | 11:25 PM
DollaGreen's Avatar
DollaGreen
Default My 4 speed is a 2 speed...
After my last problem where I got the car stuck in first gear I reached under and grabbed the shift rods and got it freed up.
Today, took the car out to find out I have reverse, third and fourth. Moving the shifter to the first or second positions gives nothing, no resistace, no clunk feeling of hitting the gear. Acts like it is in neutral. Im guessing this is just a shift linkage problem. Where do I start...point me in a direction.
:mad
Old Jun 12, 2002 | 11:39 PM
LT1driver's Avatar
LT1driver
Default Re: My 4 speed is a 2 speed... (DollaGreen)
adjust all rods in neutral positon and try again is all I can think of to start with. :confused: good luck.
Old Jun 12, 2002 | 11:56 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: My 4 speed is a 2 speed... (LT1driver)
It sounds like the 1st/2nd rod has become disconnected. You probably sheared a spring clip. I would visually inspect the linkage and all the attachment points. It also sounds like you should adjust the linkage.
Old Jun 13, 2002 | 12:38 AM
Schmucker's Avatar
Schmucker
Really if you are going to do all this shifter work you might as well go get a new shifter, look in the archives for a good one. I heard the Hurst comp or something was great.
Old Jun 13, 2002 | 12:24 PM
verskel's Avatar
verskel
Ouch ! :( .....that really sucks - a 4spd into a 2spd ???
....yeah it definitely sounds like the 1st & 2nd linkage rods aren't 'connecting' or way too loose to even work. Probably a new shifter wouldn't be a bad idea either.... Good luck ! :cheers:
Old Jun 13, 2002 | 12:35 PM
tshort's Avatar
tshort
CI 7-8 Veteran
Default Re: My 4 speed is a 2 speed... (verskel)
I kept having similar problems and in all cases either the linkage had gotten loose and got flipped in a bind or had come completely off. I ended up replacing the bolt, lock washer, and put thread-lock on it and really wrenched it down. No problems since.
Old Jun 13, 2002 | 12:37 PM
MikeC's Avatar
MikeC
Default Re: My 4 speed is a 2 speed... (burners)
I agree with burners, you shift linkage has become disconnected. check that if it isn't that, I have a few ideas, but it is probably that.
Old Jun 13, 2002 | 05:12 PM
DollaGreen's Avatar
DollaGreen
Default Re: My 4 speed is a 2 speed... (MikeC)
Thanks for the replies...the only hard part about this is getting under there. This is not what I wanted with my engine project coming up! That figures right???!!!
To My 4 speed is a 2 speed...
