Fuel lines 1969
Old Jan 22, 2013 | 09:56 PM
Captainkvan's Avatar
Captainkvan
Default Fuel lines 1969
Hello, this is my first post. I am working on my 1969 C3 350 engine. I purchased it not to long ago. It has sat for for years. Im am cleaning the gas tank. it didnt look bad inside, some varnish on the bottom but I can clean it. I am installing a new fuel sending and pick up unit. I want to clean out the fuel lines also, what is the best way to clean out any varnish that may be in the lines, or should i just install new fuel lines.
Thanks Captainkvan
Old Jan 22, 2013 | 10:29 PM
TimAT's Avatar
TimAT
Replace all the rubber lines, and you can flush the steel lines with alcohol if you feel the need to. The rubber line between the frame and fuel pump is a specialty part. The hose off the roll at the parts store will kink.
Installing new lines is an option, but probably not needed, and is not an easy thing to do without pulling the body off the frame.
Old Jan 23, 2013 | 09:50 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Blow compressed air through them. You'd be surprised at the crap you'll get out of them.
It is a major PITA to replace factory fuel lines with the body on the frame.
Old Jan 23, 2013 | 10:00 AM
mysixtynine's Avatar
mysixtynine
As long as the lines dont look rotted out then get a can or two of break cleaner and shoot it through those old lines into a can of some type. Keep your drop light away from this activity. Then blow them out good with compressed air.
Doing new lines with the body on would be a real challenge.
Old Jan 23, 2013 | 08:22 PM
Captainkvan
Thanks sounds like a good idea
Old Jan 23, 2013 | 08:23 PM
Captainkvan
I will try a little of all 3. Thanks!
Old Jan 27, 2013 | 09:20 AM
tyrant's Avatar
tyrant
Check the lines for cracks. My '69 sat for years and had a few cracks. Ended up pulling body to replace lines.
Old Jan 27, 2013 | 10:42 AM
Captainkvan
Ouch, Thanks I will check that out.
To Fuel lines 1969
