LS1 conversion question
Old Jan 23, 2013 | 05:06 AM
74batmobile's Avatar
74batmobile
Default LS1 conversion question
So ive been working on this swap for a long time, finally after a years wait ive finally had time to get under the hood.
now can i use my same radiator and just install a electric fan?
Old Jan 23, 2013 | 06:25 AM
Garys 68's Avatar
Garys 68
yep
Old Jan 23, 2013 | 11:52 AM
74batmobile
what size/speed fan would be recomended?
Old Jan 26, 2013 | 09:07 PM
donnie1956's Avatar
donnie1956
Depends on what your primary driving conditions are going to be. If you live and drive in phoneix your are going to need to push more air than a colder climate. I am going with dual fans and my controller will determine when the 2nd fan needs to be running.
Old Jan 26, 2013 | 11:38 PM
Learning_Curve's Avatar
Learning_Curve
If you go for a dual fan, google "3 relay cooling fan circuit". It allows both fans to run at a slow speed for low, or run full speed for high. The Camaro I'm using for a engine donar had this setup, so I'm replicating it in the Vette.
Old Jan 27, 2013 | 02:55 AM
DEEPSEA70's Avatar
DEEPSEA70
Default LS3 conversion
I just put my radiator and dual fans in tonight. Using 11'' Spals with copper core and original tanks. I haven't wired my computer and harness yet, so I have nothing working just yet. I'm planning on sending it all to Current Performance for that, and will wire it all up soon. Just wondering if there is an issue with the copper and aluminum heads corroding.
To LS1 conversion question
