Oil Pump Relief Spring
Old Jan 25, 2013 | 12:04 AM
boat196's Avatar
boat196
Default Oil Pump Relief Spring
The relief spring (Canton 11-250 40 -65 psi) installed in a standard pressure/volume oil pump. My question is the psi range, would this mean, that the spring installed at stock length, would produce around 40 psi. And if shimmed it could produce 65 psi.
Bob
Old Jan 25, 2013 | 02:17 PM
bashcraft's Avatar
bashcraft
I doubt it. I don't believe that manufacturers recommend shimming the spring.
Old Jan 25, 2013 | 02:48 PM
Manuel Azevedo's Avatar
Manuel Azevedo
Bob
Basically no. It is not just the spring that sets pressures it is all the clearances in your engine combined with the pumps ability to pump pressures, so all they are really saying is that if all is good your pressures "could" be somewhere in that range!
Old Jan 26, 2013 | 01:37 PM
Matt Gruber's Avatar
Matt Gruber
i put 2 washers and it boosted my M-55 to 65-70, more than i guesstimated.
best thing is to make a test fixture.
Old Jan 26, 2013 | 01:46 PM
jimboscarbs's Avatar
jimboscarbs
Default oil PSI
yes it will make a difference
if you do not have it, go buy Dave Vizard's book on the Small block
"How to Build Max Performance Chevy Small Blocks on a Budget"
He has a really good write up in there about preparing an oil pump and also expounds a bit on its effect on ignition performance.
and as bad as I hate the "Zone", they carry his books... around $20.00
Best Regards, Jim
To Oil Pump Relief Spring
