My New Favorite Tool--
Old Jun 13, 2002 | 01:28 PM
JB's Avatar
JB
St. Jude Contributor
Default My New Favorite Tool--
A 56" length of 3/4" PVC pipe. Found a techtip by gary dion (cluchdust) in the tech forum for bleeding your brakes by using the pipe to press the pedal. I can stand outside the car, pump the brakes slowly with the pipe, then "bow" it and put the open end over the door striker and it holds the pedal down while I walk around and crack the bleeder. Marvelous!
So today I'm trying to figure out how to turn the engine over myself while watching for a spark. I can reach through the gap between the door and the windshield and turn the key and see the engine, but I can't hold the darned clutch in to engage the ignition cut out on the clutch. Then I remembered the trusty PVC pipe. Worked like a charm.
$.80 at Lowes. I love stuff like this!
JB
[Modified by JB, 11:29 AM 6/13/2002]
Old Jun 13, 2002 | 02:08 PM
norvalwilhelm's Avatar
norvalwilhelm
Default Re: My New Favorite Tool-- (JB)
I have a starter switch on a long cord that I use on my mustang to bump the starter. It jumps across the solenoid and by pressing the button the solenoid is energized and the motor is turned over. The clutch has to be in for normal starting but when you bypass the ignition by clipping onto the solenoid this saftey device is overrode. I also have the same ford external solenoid on my vet so the same starter works. I don't know if you can just jump to the starter solenoid or not but this external starter is great for setting valves.
Old Jun 13, 2002 | 02:14 PM
Tominator's Avatar
Tominator
My new favorite is a distributor nut wrench, got two differnt sizes for under 5 bucks. It makes the job less frustrating. :cheers:
Old Jun 13, 2002 | 03:35 PM
TerryN68's Avatar
TerryN68
Homemade vacuum pump constructed from an old bicycle pump.
Can test those headlights without starting the motor. You can actually hear any leaks.
T
Old Jun 13, 2002 | 03:49 PM
BB wowbagger's Avatar
BB wowbagger
Default Re: My New Favorite Tool-- (TerryN68)
Got the same tool in my garage..Priceless..
Old Jun 13, 2002 | 04:32 PM
honaker's Avatar
honaker
That's better than using the dishwasher as a parts cleaner and a cat for a hand towel. I like the bicycle pump idea.
Old Jun 13, 2002 | 05:08 PM
Koz
Guest
Posts: n/a
T
I need pictures.. :cheers:
Old Jun 13, 2002 | 09:44 PM
PRNDL's Avatar
PRNDL
Default Re: My New Favorite Tool-- (Koz)
I am wondering about the bicycle pump also. Do you use it to create vacuum or pressure?? :confused: MJ
Old Jun 14, 2002 | 04:12 AM
Turbo-Jet's Avatar
Turbo-Jet
Default Re: My New Favorite Tool-- (honaker)
:lol: :lol: :lol:
Old Jun 14, 2002 | 11:11 PM
dogboy's Avatar
dogboy
Default Re: My New Favorite Tool-- (Turbo-Jet)
mini sledge hammer
To My New Favorite Tool--
