got a quickie
Old Jan 27, 2013 | 03:09 PM
79vetter's Avatar
79vetter
Default got a quickie
I touched the red terminal on the back of the alternator with a screwdiver and heard a little electrical zing...Now the car is dead, no lights... nothing..I checked the fuses and they look ok.
um, what did I just do?
Old Jan 27, 2013 | 03:19 PM
my 76 ray's Avatar
my 76 ray
From the title I thought you got lucky, but after reading your post I think you fried the fusible link.
Old Jan 27, 2013 | 03:21 PM
TedH's Avatar
TedH
The red terminal on back of alternator is HOT (+).
You may have shorted something in the alternator (voltage regulator or diode trio) that regulates the voltage back to the rest of the car. May be worth taking it to the local parts store for test.
Stores will test alternator for free.
Old Jan 27, 2013 | 03:43 PM
spdrcr29's Avatar
spdrcr29
Chances are pretty good something is blown...just a matter of where. Double check fuses. Even if alternator is fried, car should still at least crank over and start. Possible that there is fuse link that was blown down at the starter?? Do you have a volt meter? Is there still 12v at the red wire at the alternator? Do you have 12v at starter? Do you have 12v at starter with ignition key in start/crank position? All things that should probably be checked. Good luck!
Old Jan 27, 2013 | 03:53 PM
79vetter's Avatar
79vetter
I have 12V at the battery
I have 6V at the back of the alternator. Car is completely dead.
Shouldn't I have interior lights at least if the battery has 12V?
Old Jan 27, 2013 | 04:04 PM
spdrcr29's Avatar
spdrcr29
Not so sure about interior lights...still think that whatever is blown might be affecting your interior lights also. What year is your vette? If you only have 6v at the alternator, trace that wire backwards. I believe it runs down to starter, but could be wrong. If you can find where that wire originates from, check the voltage at that point and see what you have. If 12v, move towards the alt to see where it changes from 12v to 6v and fix as necessary.
Sorry bud, wish I could be there to help you out!
Old Jan 27, 2013 | 04:51 PM
'75's Avatar
'75
You fried a fusible link at the starter, check the wires there, you will likely find one that is burnt.
Old Jan 27, 2013 | 09:10 PM
redrdstr72's Avatar
redrdstr72
Don't ask me how I know
Old Jan 28, 2013 | 09:14 PM
spdrcr29's Avatar
spdrcr29
Any updates for us Goliath?
To got a quickie
