Accell HEI weirdness
Old Jan 27, 2013 | 07:44 PM
FriscoScooterTrash's Avatar
FriscoScooterTrash
5th Gear
Default Accell HEI weirdness
Engine was running fine when I parked it. A couple of weeks later it won't start, not a cough on cranking.
Confirmed fuse, power to coil, coil resistances, coil pickup resistance, mechanical / vacuum advance, all connections, wires, everything bench tests fine.
Reassembled, engine started right up and ran fine, like normal. Anyone else experience this? Ever figure it out?
Old Jan 27, 2013 | 09:04 PM
TW1ST3D's Avatar
TW1ST3D
Mine did that. I found that the button wasn't seated correctly. After cleaning and reseating the button, all has been good for the last 6 months.
