MSD-6A question
Old Jan 31, 2013 | 06:21 AM
Belgian1979vette's Avatar
Belgian1979vette
Default MSD-6A question
did someone with a large duration, big overlap cam ever use an MSD-6A to cure idle issues. Did it help ?
Old Jan 31, 2013 | 08:58 AM
ezobens's Avatar
ezobens
An MSD-6A isn't going to cure your idle problems any better than any other well maintained and adjusted ignition system.
Old Jan 31, 2013 | 09:40 AM
SuperBuickGuy's Avatar
SuperBuickGuy
it does smooth the idle out... cure? umm, not sure that'd be the word I'd use.
Old Jan 31, 2013 | 09:48 AM
63mako's Avatar
63mako
St. Jude Donor '08-'09
It does help some at lower rpm.
Old Feb 1, 2013 | 03:43 AM
Belgian1979vette
Okay, if that's the case there is no reason to spend the $200
Old Feb 1, 2013 | 03:33 PM
TimAT's Avatar
TimAT
I went down that road too. I used a Mallory CD box with a rev limiter. Went back to the factory TI. Easier starts and better idle with the TI than I ever got with the Mallory. IT's still on the car, and a pretty simple changover in case the 40+ year old TI gives up. It'll get me home.
Old Feb 1, 2013 | 04:07 PM
C3 Stroker's Avatar
C3 Stroker
The ignition itself doesn't cure idle issues, but recurving the distributor to allow more initial timing while maintaining optimum total timing (approx. 35°-38°) will help tame the idle of a high overlap cam.
Old Feb 1, 2013 | 07:25 PM
Corey_68's Avatar
Corey_68
My 6AL helped with idle quality and helped with initial start-up.
Old Feb 1, 2013 | 08:03 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
The 6AL definitely improved my idle. Enough to justify the cost? Not so sure. It definitely idles and runs better than it did with the HEI unit that it replaced.
Old Feb 1, 2013 | 08:20 PM
garygnu's Avatar
garygnu
maybe try some lighter springs.whats your vacuum at idle in gear ?dose your distributor have a adjustable vacuum canister ?
Old Feb 1, 2013 | 08:40 PM
drwet's Avatar
drwet
My cam is not huge. Its a hydraulic roller with about 230 deg at .050 but it idles a little rough. Not sure why such a mild cam has a rough idle, but the Comp Cams catalog even says it idles rough. The MSD 6 definitely smoothed out the idle. Didn't provide much other advantage though.
To MSD-6A question
