epoxy primer
Old Feb 1, 2013 | 12:50 AM
merc49's Avatar
merc49
Default epoxy primer
Can i use 2 part epoxy primer sealer on a c3.i get it for free and have used it with great results on steel cars but have never painted fiberglass.i am painting the whole car.i also get the same mfg. paint so there wont be any problems.
Old Feb 1, 2013 | 01:45 AM
wombvette's Avatar
wombvette
Certainly
Old Feb 1, 2013 | 07:09 AM
cb.bums's Avatar
cb.bums
when you say sealer, that usually means it's being used to separate older finish from new finish. epoxy primer is usually intended to give good adhesion on bare surfaces for new paint. primer can fill some bad areas and can and must be sanded if not painted soon after application. fiberglass is so porous that most good primer surfacers will give good adhesion.
Old Feb 1, 2013 | 09:26 AM
stpman's Avatar
stpman
Originally Posted by wombvette
Certainly
Get the data sheet for the epoxy and it will tell you how you can use it
Old Feb 1, 2013 | 11:50 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Bingo.
Old Feb 2, 2013 | 09:46 AM
Rotonda's Avatar
Rotonda
If you click the "FORMS" icon in the red bar, you will find a Forum tittled "GENERAL CORVETTE" click it and you will find a forum tittled "PAINT/BODY". They have a lot of useful info about using an epoxy primer on Corvettes. Pay attention to members Porchdog and Dub especially.
Old Feb 2, 2013 | 09:16 PM
tommy1727's Avatar
tommy1727
Yes, you can use epoxy primer. In fact it's absolutely what should be used! Good luck with the project!
To epoxy primer
