Build Advice
Old Feb 2, 2013 | 11:33 AM
70GreenonGreen's Avatar
70GreenonGreen
Navigator
Default Build Advice
Hello All,
I have some questions for the group here. I bought a project. Not a HUGE project, but a project nonetheless. 1970 Corvette. Was a 350/TH400 car. I would like to know what everybodies opinion is here on a few things. Keep in mind, the car will be a cruiser, just for driving to car shows and around town with the ever so occasional tire roasting.
1. Suspension. Should I go ahead and do a sport suspension upgrade considering it is a 40 year old car? If so, which is the best.
2. Steering. Rack and Pinion or leave alone? Which kit is best?
3. Brakes. Are the factory sufficient? Or upgrade to a nice aftermarket kit? Which one?
4. Drivetrain... NOw we have alot of options. I have easy access to old school, small blocks to big blocks, supercharged to whatever. I am leaning more towards a LS style sway...probably a 6.0 upgraded with a 4l80. BUT....if I can get HP3 version of the 8.1 (525 hp) I am liking that idea.....8.1/4l80.
Now, I understand everybody has their own opinions but I would like to collect ideas from the professionals here and make my own choices based on peoples past experiences.
Andy
Old Feb 2, 2013 | 08:13 PM
garygnu's Avatar
garygnu
whats your budget ?I seen where a rack has problems with oil pan clearances .consider a ls2 ,its the aluminum 6.0 . or consider a bored and stroked ls2 for 402+ ci,Texas Speed has good prices on ls motors.would a gearvender over drive fit in a vette behind a t400.
Old Feb 2, 2013 | 08:35 PM
John 65's Avatar
John 65
I am faaaaaaaarrrrrrrrrrr from a pro, but I would :
Rebuild your stock suspension.
Rebuild your stock steering.
Rebuild your stock brakes.
Then put a big fat big block in there and have some fun. Of course to do so would require several small block to big block conversion changes to be made. Good luck and enjoy it!
Old Feb 2, 2013 | 08:43 PM
drwet's Avatar
drwet
I have a '79 with the Vette Brakes Grand Touring Plus suspension kit with KYB shocks. Great kit. I love the handling. I also have the Steeroids Rack and Pinion conversion. Also a great upgrade. As for brakes, mine are stock and its hard to imagine why you would need better brakes on the street. The stock Corvette brakes are very good. As for drivetrain an overdrive transmission is a must, whether its a 4 spd auto or a 5 or 6 speed manual. For an engine there are lots of good choices. I have a 383 stroker, but if I was doing it over again, it would be an LS motor. The power those things make is just sick!
Old Feb 2, 2013 | 08:51 PM
TedH's Avatar
TedH
Originally Posted by 70GreenonGreen
Hello All,
1. Suspension. Should I go ahead and do a sport suspension upgrade considering it is a 40 year old car? If so, which is the best. I would go with STOCK rubber front and rear kits from Van Steel (front suspension rebuild kit and rear rubber bushings).
2. Steering. Rack and Pinion or leave alone? Which kit is best? Refresh with a (power steering?) rebuild kit from above-mentioned dealer.
3. Brakes. Are the factory sufficient? Or upgrade to a nice aftermarket kit? Which one? Refresh with OEM-grade replacements from above-mentioned dealer
4. Drivetrain... NOw we have alot of options. I have easy access to old school, small blocks to big blocks, supercharged to whatever. I am leaning more towards a LS style sway...probably a 6.0 upgraded with a 4l80. BUT....if I can get HP3 version of the 8.1 (525 hp) I am liking that idea.....8.1/4l80. I'd go with a 350rwhp target for your intended driving habits... easily achievable with a hop-up of your Gen 1 350. Add rebuilt components (driveshaft rearward) from above-mentioned dealer.
Andy
See bold comments.
Old Feb 2, 2013 | 08:53 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Rebuild suspension, rebuild sterring, rebuild brakes and bolt in a 540 EFI big block with a TKO 600 and 3.70 gears.
http://www.ultrastreet.net/engines/5...street_efi.php
Old Feb 2, 2013 | 10:39 PM
iree75's Avatar
iree75
LOL.. why stop at 540 ... if your going to go big ... go big
http://www.sonnysracingengines.com/e...p-new-for-2013
I agree with rebuilding all the stock stuff.. but these days a decent small block can be built for cheap and save you the weight (and ill handling). I'd say look at a 90's one piece main seal block with roller cam capability. Build a nice roller 383.. and save some $$ for your kids education or beer or tequila or a two post lift.
.. although there is no sound quite like a bbc
Old Feb 2, 2013 | 11:55 PM
63mako's Avatar
63mako
It isn't a bolt in. The 540 is a easy bolt in. Exhaust ports are even stock location. It is a 625 hp, under 10 to 1 hydraulic roller, very streetable engine that runs on midgrade. and with thev EFI TKO will likely get 20 MPG on the highway. A 70 vette needs a BB. 5 speed.
Old Feb 3, 2013 | 07:54 AM
diehrd's Avatar
diehrd
Forget the BBC ,, go SBC 427 direct bolt in less weight and as much hp then that 540 and it will run on pump gas !~!
Old Feb 3, 2013 | 08:58 AM
Matt Gruber's Avatar
Matt Gruber
for a few dollars more, buy a 2014 stingray
Old Feb 3, 2013 | 11:05 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by John 65
I would : Rebuild your stock suspension. Rebuild your stock steering. Rebuild your stock brakes.
Nothing aftermarket required for what you say you want to do with the car.
To Build Advice
