81 Corvette
Old Feb 6, 2013 | 07:43 AM
knightvette81's Avatar
knightvette81
Cruising
Default 81 Corvette
I have an 81 Corvette I have let sit for along time and now the transmission doesn't want to change out of first gear. It is an automatic it changed out a few weeks ago now it doesn't want to work. It has plenty of fluid in it don't know what to do. Thanks for any suggestions
Old Feb 6, 2013 | 09:31 AM
wombvette's Avatar
wombvette
Pry the cover off the governor. Remove and clean the governor up. Weights and plunger probably sticking.
Old Feb 6, 2013 | 10:30 AM
knightvette81
Cruising
Default 81 Corvette
Thank you for the fast response That is something I need to try. Thank You again
Old Feb 6, 2013 | 11:46 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
At what point are you measuring tranny fluid level? Engine and tranny need to be at operating temperature when you check.
Old Feb 6, 2013 | 12:11 PM
texas jim's Avatar
texas jim
An automatic not up-shifting? It's either the line or the modulator itself. Replace the rubber vacuum hose going to the modulator or if it's not that, it's the modulator itself. No Big deal. AND NOTHING ELSE. And possibly the line came off, period. No need to do a bunch of extra work. I have a twenty dollar bill that says it's the line.
Old Feb 6, 2013 | 05:46 PM
gingerbreadman1977's Avatar
gingerbreadman1977
Im with Texas. i put a 20 on the vacum hose coming off as well.
To 81 Corvette
