Slicone brake fluid
Old Jun 14, 2002 | 11:58 AM
Bond007's Avatar
Bond007
Default Slicone brake fluid
Hello fellow Vetteheads, in an earlier post I asked for opinions on silicone verses glycol based brake fluids and received some good feedback, however I forgot to ask when I disconnect the brake lines from the calipers and from the master cylinder to blow out the old Dot 3 is there a solvent I should run through or do you think air will do the job.
Peter :confused: :flag
Old Jun 14, 2002 | 08:41 PM
glen242's Avatar
glen242
Default Re: Slicone brake fluid (Bond007)
Flushed my system with denatured alcohol before in installed the DOT 5.
Old Jun 14, 2002 | 11:35 PM
RJR99SS's Avatar
RJR99SS
yeah, cheap rubbing alcohol will work. but be very sure to do a good job flushing it, glycol and silicone brake fluid dosnt work well together...
Old Jun 15, 2002 | 09:22 AM
Bond007's Avatar
Bond007
Default Re: Slicone brake fluid (RJR99SS)
Thank You all will get the alcohol tomarrow, Monday is the the big brake day wish me luck.
Peter :cheers: :flag :seeya
[Modified by Bond007, 7:23 AM 6/15/2002]
To Slicone brake fluid
