air cleaner set up
Old Feb 7, 2013 | 02:39 PM
MACHEEN's Avatar
MACHEEN
Default air cleaner set up
I want to change out this original setup with the air cleaner that has the housing with two intakes and sets up against the hood when closed. I Like the chrome look with the exposed filter. What about the breather element? What connects to that then? Will this affect performance and need any carb adjustments?
Old Feb 7, 2013 | 03:20 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
What set up do you have now and what set up do you want to use?
Old Feb 7, 2013 | 03:33 PM
MelWff's Avatar
MelWff
I believe you want this, there should be no adjustment needed, but a picture of your current carburetor would help to insure fit.
http://willcoxcorvette.com/product_i...oducts_id=1375
http://willcoxcorvette.com/product_i...oducts_id=6521
http://willcoxcorvette.com/product_i...oducts_id=6086
Old Feb 7, 2013 | 06:42 PM
MACHEEN's Avatar
MACHEEN
yep that's what I want to put on it. Everything is stock now. would like to dress it up some.
Old Feb 7, 2013 | 06:47 PM
MACHEEN's Avatar
MACHEEN
http://forums.corvetteforum.com/memb...0&ref=gnr-prev
To air cleaner set up
