Axle u-joint?
Old Feb 9, 2013 | 10:06 PM
cwaynem's Avatar
cwaynem
Default Axle u-joint?
After fixing the horn, parking brake, and multiple oil leaks, my 76 is now safety inspected and legal for the streets in Texas for the first time since '06 (the last time the PO had it registered)! I took it for about a 50 mile round trip today. That is probably the longest it has been driven in a very long time. That's the good news. Unfortunately, I think I found a new problem and I can use some help. On the right rear, I noticed the top of the tire is leaning into the body (or the bottom is out, not sure which) and I noticed as I was pulling it back into the garage that there was a rhythmic clunk coming from that side. I did not notice anything unusual at road speed, just when it was barely rolling (but then the pipes aren't exactly quite ). Could that be the axle u-joints on that side? Would bad u-joints give it a negative camber or am I looking at something else?
Old Feb 9, 2013 | 10:30 PM
cwaynem's Avatar
cwaynem
I measured both rear tires. The driver's side is about 3/4" negative and the passenger side is 1-3/4" negative. Enough to see and I would think I would have noticed it before.
Old Feb 9, 2013 | 10:41 PM
briankeery's Avatar
briankeery
Sound like you're in the market for at least new strut rod bushings. If you wish, you could swap the originals for adjustable strut rods.....both have their merits according to everyone here; do your homework and decide what's right for you. As for the noise, check your rear differential fluid level first....don't forget the posi additive. Once these two things have been fixed, see where you're at.
Old Feb 11, 2013 | 02:07 PM
tracdogg2's Avatar
tracdogg2
Wayne,
You are about 10 miles from me. I'd be happy to look at it for you and tell you whats wrong.
Mike
Old Feb 11, 2013 | 11:53 PM
cwaynem's Avatar
cwaynem
Thanks Mike. Email sent.
Old Feb 11, 2013 | 11:55 PM
cwaynem's Avatar
cwaynem
Thanks. New Strut rods ordered. Stopped by tonight to get diff fluid and additive. Will check it out tomorrow night.
Old Feb 12, 2013 | 10:05 PM
cwaynem's Avatar
cwaynem
Good call on the differential fluid. It was 1/2 qt low. I was surprised at the fill bolt after all the horror stories told about getting it loose. Mine was barely tight. Maybe that is why it was damp around the bolt. It is full and the bolt is tighter now. Do I need to add posi additive when I just top it off?
I will give it a test drive when it stops raining.
Old Feb 13, 2013 | 08:05 AM
briankeery's Avatar
briankeery
Nice one Wayne, I was told to do some "figure 8's" in a parking lot to work the fluid into the clutches. The additive I believe is used to prevent the fluid from foaming up - some of the other guys can correct me on this info if I'm misinformed. I've been told by my mechanic that if you use a synthetic gear oil, you can forgo the additive. Mine also made some noise when I bought it, this procedure remedied the problem. Hopefully it takes care of yours also, and you can start putting some miles on her. Good luck.
Old Feb 13, 2013 | 11:24 PM
cwaynem's Avatar
cwaynem
Took it for a very short ride tonight. One clunk when I started backing out, then ... nothing. Not absolutely sure if low oil was it, but it is looking good. When I got back, I put on KYB Gas-a-Just shocks on all 4 corners. The old ones were really shot. When I lowered the car off the jack stands, the camber on the passenger rear did not look as bad. I did nothing to the strut. Would shocks change the camber or is it just my imagination?
Old Feb 14, 2013 | 01:29 AM
briankeery's Avatar
briankeery
If you didn't roll the car a few feet after she came off the stands, then the suspension wasn't fully settled. Start soaking the strut rod bolt areas with PB Blaster,or something similar,as you wait for your new rods. What ones did you go with?
To Axle u-joint?
