Doesn't really matter. I would expect a high dollar built solid cammed 418 to be shifting in the 7k rpm range on the strip. That is converted single plane manifold territory.
At any rate, the point still stands. A properly build and tuned 418 would walk all over your mostly stock 350 cross fire build.
I almost get it now. You found a 15 year old magazine article that shows how a very optimized cross fire can run a decent time at the strip and decided to post about how you're using it as a basis for your build. I'm not sure why you have to rant about it though.
Did'nt just FIND an old mag. had it since [I bought my 82 IN 2000.]
And yes I applied that buid to my engine w/a few different mods. SINCE that was waaaay back in 1997 our tech and knowledge has advanced.....since then.I should have never posted that POST cas dam! my intent was to HELP not ARGUE.
The cap. letters are just for a point..........not a rant.
What do you think is the limit on horse power on a stock CFI intake? I love my CFI and I plan on keeping it when I install my 406 or I may do a 383 but I will be building for torque not horse power. I'm expecting no more than 5500rpm with over 400 ft lb of torque by 2800rpm
Somethings says the FIRST car had a real soft 60 hes making good power by his trap speed. Glad youre happy with the crossfire.
porting a FIRST this coming week, igoal is 11s on a mild 383 C4
I agree.
I'd think that traction was some what of an issue. Theres another member dont remeber who that has 600 some horse and didnt do much better, but 60' was weak as well as the smoke trail out to the 1000' mark.
12 seconds is a quick street car, my daughters 400 horse 2011 mustang gt 5.0 runs 13.00 according to ford.
I've heard about extrusion honing, opening between the runners to double the flow............................... I also have met people in love with their VW stroked out, hot cams, dual webers. But it all comes back to: What do you really have? I had a winning bracket racer low 12 second at 4500 feet 350 vette with a edelbrock carb.
All the chicks were over looking at the supercharged 8.50 second 69 Pro street camero!
PS, does M P stand for military police?
Limit of CF intake w/ no porting? thers a lot in that question. Not much IMHO, however w/ A LOT of porting probably 375-400hp MAX w/ many other modifictions[at the crank]. A food for thought is the soon [we all hope] to be released renagade intake w/ the right combination that intake will support well over 400hp w/ other modifications. If you use the stock intake you will need to do A LOT of port work to get it to flow enough to support near 375-400hp at the crank. and getting the rest of the combination right, ie: Tb's. injectors, heads, cam compression ratio, exhaust etc....With the renagade to maximize its possibilities you will need to do similiar modifications only with the renagade expect more total hp and at a higher rpm.
Unless you go nuts porting the CFI it will strangle that 400 at a very low rpm., Even ported it will choke it just not quite as bad. Over 400 lbs
I spent many hours porting my stock CF put it this way I will NOT port another one, whew! My pockets are not that deep [now] so I have to make compromises, and I have alot of friendsthat help me a lot!!
I personally don't know about it to much ONLY 2 friends had it done and ended up doing a basic port job after the extude honing, they were not happy. IMHO for keeping things closer to stock and you got the money it MIGHT be ok? BUT more max hp get the porting tools out or have a good shop do it for you.
IMHO I would'nt go to that many cubes keeping the stock CF MAYBE a 383 w/ALOT of port work on the CF and w/ the right heads and cam and expect to bore your TB's out and a increase in injector size. Thats why I only went to the 355cid on my build. More cubes more air, more fuel, more money. And good luck on your cardo alot of research 1st.
12 seconds is a quick street car! I am hoping for 13,s w/ my car [not going to change the rear gear] And yes traction would be a problem..........I have a 1990 SS454 pick-up [factory truck a w/flare-side bed-not factory] the flare side is lighter then the fleet-side, fiberglass fenders and a the track my truck just went up in smoke [very poor 60ft time : expected that] NO traction...all I could get out of it was high 14,s@94mph trap speed's making GOOD power, got better times by pretty much idling of the line,[engine re-built 0.30, mild cam, ported heads & ported stock manifolds, 3 inch exhaust w/gutted cat & hyper-tech chip.] 400 turbo trans w/factory 3.73 rear gear posi unit. Need slicks and some weight on the rear.....not doing ALL that. Just wanted to see what I gained over stock since the stock times where in the mid-high 15's BTW ,My SS truck now only weighs 4060lbs [below the stock weight of about 4400lbs-4500lbs]
12s is good period with a Crossfire I mean come on those were horrible manfolds lets face it. Followed by the most convoluted one ever the TPI.
Most guys grinding on their crossfires with converters are barely cracking 13s. Hell...12. something woulda spanked my 90 ZR1 and that put around 340 to the ground
Ive seen guys struggle with head/cam/Xfire lids and get mid 13s tops
Not bad at all.
Not bad at all.
From my research the engineers at GM kinda/sorta used the old Cross-Ram intake putting 2/4 barrel carb's over the valve covers making high horsepower used on the hi-po 302/Z-28's cars [very rare] for an IDEA however they choked it up soooo much it is in stock configuration very limited, it AND the tbi's are too small for a 350cid engine. You gotta port the heck out of it to get it to flow enough air for a 350cid engine. ZR1's were very stong [never had one, friend in Fla. did] did ya every havta change a starter on your ZR1????
Smoke trail out to the 1000' mark!!!!!! OMG-LMAO!!!!!!!YEP TRACTION IS AN ISSUE!!!!!Still laughing!!! To the point of tears!!!!
Not bad at all.
The TPI was'nt much better IMHO what 30hp-45HP more maybe? IMHO the real gain is in the heads AND the right combination, along with it.?. I made A LOT of mistakes in the past by putting the wrong combo together and getting poor results ie: too big of cam, wrong heads etc,etc,etc. Thats why now I do a lot of research 1st before I touch................................... ......... anything!........:thumb s:
Never had to replace it but its easy. Plenum comes off quicky below it are coil packs under that the starter. All the pertinent stuff is under the plenum theres no room under the car for anything. Try a waterpump on one of those
Glad to hear youre happy with your results.
Something for everyone out there.
The z28s used the cross ram manifold to give longer runners without having to use a tunnel ram to follow the "keep it in your pants" Trans Am rule (not sticking out of the hood). In fact the edelbrock version of the manifold was called the STR for Street Tunnel Ram.
The Corvette crossfire was just a way to give the the Corvette fuel injection using four cylinder throttle bodys already developed at that time. One throttle body could not feed a 350, so they just developed a manifold that allowed the use of two.
When I was first planning my project, I really wanted a crossram. My thought was to use two 350 tbi throttle bodies on an offenhauser manifold, but I couldn't find any used and couldn't justify 500 bucks on just the manifold.
I would like to see that done on a hotter or larger SBC. Long as you could tune to get past the plenum size I bet it would run good or would hope anyway. Perhaps aftermarket EFI to control it as they dont come alive til high rpm anyway? Sure would have some appeal popping the hood.
The idea was to use it on a 400 I had at the time. I was planning on using a Megasquirt controller, as they can be programmed to run just about any combo. And though I couldn't find anyone that had ever tried it, I did find a case of dual tbi being used on an inline dual quad manifold.
Just thought it would be something different that would perform with junkyard parts.
Might have been better off with 2.8 or 4.3 throttle bodies to cut down on injector flow.
