ls6 bbc
Old Feb 10, 2013 | 04:36 PM
jimmybrown's Avatar
jimmybrown
Cruising
Default ls6 bbc
could someone tell me the last four numbers for a stock intake that will fit 990 square port heads not sure what to bid on ebay thanks
Old Feb 11, 2013 | 04:50 AM
Big Block 69's Avatar
Big Block 69
3963569 is one of a very few stock ones that will fit under a stock hood
Old Feb 11, 2013 | 12:51 PM
jimmybrown's Avatar
jimmybrown
Cruising
ok thanks
Old Feb 16, 2013 | 02:29 AM
RickyBerg's Avatar
RickyBerg
There is a company that produces brand new LS6 intakes, quality is very good and all the original numbers and "snowflake" is there awell.
I bought one for my own LS6 replica after looking at old cracked intakes with broken threads and so on at E-bay.
If you add the original reproduction LT-1/L88 Air filter base and a 3" airfilter you will be able to add a 1/2" spacer inder your Holley and it will still fit under your stock bigblock hood.
These intakes are brand new!
http://www.thepartsplaceinc.com/ocat...ch_Keyword=LS6
1970-71 CHEVROLET LS6 L78 299.00 299.00
L89 ALUMINUM INTAKE
MANIFOLD 3963569
1Z08186X0363228590
To ls6 bbc
