Fireproof Bushings?
Old Feb 10, 2013 | 05:14 PM
ted13b's Avatar
ted13b
Default Fireproof Bushings?
I'm trying to burn out the lower control arm bushings on my C3, as I've read in several forum posts. I tried lighting them with a propane torch...they'd burn for a minute or two, then fizzle out. I tried dousing them with liquid wrench, then lighting them, same thing. Do I have magical, fireproof bushings, or am I missing something?
Old Feb 10, 2013 | 06:11 PM
pancake's Avatar
pancake
You need more heat. Try oxy/acetylene. They will burn.
Old Feb 10, 2013 | 06:13 PM
slofut's Avatar
slofut
Ted,
Do read my post in this thread, next to last one. All four A-arms can be a ten minute job tops!... PM me if you'd like.
Bill
http://forums.corvetteforum.com/c3-g...g-removal.html
Old Feb 10, 2013 | 08:37 PM
gcusmano74's Avatar
gcusmano74
Yes. But be careful. Use a small tip. Too large a burning tip and you will burn holes right through the steel.
Old Feb 10, 2013 | 08:53 PM
briankeery's Avatar
briankeery
STAY AWAY FROM HEAT.....air chisel is all you need.
Old Feb 10, 2013 | 09:34 PM
JB4571's Avatar
JB4571
Here's what I did on my 80' worked great, went to auto zone and use the loaner tool deal "bushing press" came with several different fittings, pressed old ones out and new one's in...went really smooth.
Old Feb 11, 2013 | 06:49 PM
ted13b's Avatar
ted13b
I got a tool from Advance for the uppers, but they didn't list one for the lowers. I think I'll try slofut's drill. thanks for the help guys.
Old Feb 11, 2013 | 07:05 PM
tomgallucci57's Avatar
tomgallucci57
drill them out with a small drill bit,then pick out the loose rubber,worked for me
Old Feb 11, 2013 | 07:18 PM
billcarson's Avatar
billcarson
it is amazing to me how many ways there are to do a job.i put a 14'' pipe wrench on the outer lip and unscrewed them.i know they are not threaded but they came out regardless.
Old Feb 12, 2013 | 05:21 PM
slofut's Avatar
slofut
Hey, now that's cool!
To Fireproof Bushings?
