Quadrajet Help, Please
Old Feb 10, 2013 | 09:20 PM
Hans4real's Avatar
Hans4real
Default Quadrajet Help, Please
After installling new 3" exhaust in my '71 BB, I wanted to do a little jetting to fine tune a prefectly good running car. Well, what is the old saying (can hear my father's voice right now), don't fix what ain't broke, it's so true. Old carb, disassemble, reassemble = not so good results, leaking and poor running. After several additional disassemble - reassemble sessions, plus a rebuild kit, I finally got it to run about as well as before I started messing with it. Yet one condition will not go away, when I hit the brakes hard it wants to stall like it is flooding out. And when it does stall I have to hold it WFO to get it to start again so, I think it is getting a big dose of gas some how during deacceleration. When it fires back up a black puff of smoke floats out the back. Any clues or suggestions on where to start the fix from my fellow Quardajet brothers (or sisters) would be much appreciated.
Old Feb 10, 2013 | 10:41 PM
gve's Avatar
gve
I would try lowering the float level a little, its flooding from the high gas level in the bowl.
Old Feb 11, 2013 | 09:18 AM
gcusmano74's Avatar
gcusmano74
Yes. Sounds like it.
How new is the float?
Brass or plastic?
Try lowering the float a bit. Maybe 1/8" below where you are now.
Old Feb 11, 2013 | 09:22 AM
Street Rat's Avatar
Street Rat
Contact Lars here on the forum. He is the Quadrajet guru around here.
Old Feb 11, 2013 | 06:50 PM
Shark Racer's Avatar
Shark Racer
Make sure your float level is to spec; lars recommends .375" for a 4M carb and .420 for an M4M. (Yours should be a 4M)
Also, verify that the needle clip for the needle is attached to the hump on the float arm, on the side of the float arm between the float arm and the float itself. If it is in one of the holes the needle may not seat correctly and cause flooding.
What did you change while you were in there, aside from replacing gaskets and hitting stuff with carb cleaner?
Old Feb 13, 2013 | 01:54 AM
jimboscarbs's Avatar
jimboscarbs
Default float level
Float level,
also float level affects fuel curve...
lowering the float level will also lean the overall performance up a bit
Old Feb 13, 2013 | 11:17 AM
Hans4real's Avatar
Hans4real
First, thank you for all the replies. After further inspection, It looks like the top plate is bent. With a flat edge there was a gap of about 1/16th of an inch at the center when placed flat. Did my best to bring it back true with the vise and some manipulation but can't exactly tell if it is totally flat again. Looks close. I think until this is resolved it's hard to say if the because it not completely flat if that is my issue. I'm going to try and find a thicker top gasket as the new one in the rebuild kit is real thin, crap from local parts store.
Old Feb 13, 2013 | 02:58 PM
Shark Racer
Contact Cliff at Cliff's High Performance. Have your carburetor part number on hand, he sells a thick gasket that works great!
Old Feb 13, 2013 | 04:54 PM
Hans4real's Avatar
Hans4real
Brass or plastic?
It about 10 years old and is plastic. I've tried lowering it but doesn't help. In my previous post I noted the airhorn is/was bent. Looking to add a thicker gasket to make the next attempt to cure.
To Quadrajet Help, Please
