Today, I noticed very small leaks on the drive way. Leak spot is next to my left front tire, way away from the engine and power steering fluid chamber. So, I figure it's brake fluid. Went under the car saw where the brake fluid was leaking from and took a picture.
Can someone tell me if this is brake line distribution blocks? I've drew a red arrow pointing at it.
Thank you.
[IMG][/IMG]
You are pointing to the outboard end of your power steering control valve. The brake proportioning valve is located about 1 foot higher/above and mounted on top of your frame rail.
It looks to me that the leak is the power steering control valve and the lines connected to it. Nothing to do with the brakes, IMHO.
Pete
Too slow typing...
