Heater fan wiring
Old Feb 13, 2013 | 08:37 AM
commander_47's Avatar
commander_47
Default Heater fan wiring
I have an 81 with all new heater/A/C components.
It all seems to be working well, including the fan running all the time.
I read in earlier posts that a brown wire can be removed from the plug on the relay on the firewall under the hood on the passenger side, but my car doesn't have a brown wire.
Could someone tell me which wire to remove from the plug to turn off the low fan running all the time?
Old Feb 13, 2013 | 09:22 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
If memory serves, the brown wire is in the connector to the fan switch and not under the hood.
Old Feb 13, 2013 | 07:55 PM
SIXFOOTER's Avatar
SIXFOOTER
Looks like you can delete the brown wire from the resistor pack, you will only have 2 speeds, but it will shut off.
Old Feb 14, 2013 | 08:55 AM
commander_47
I bent the terminal for the brown wire down and put the plug back on, and none of the settings worked.
When I put it back up, it works normally. It appears the brown wire is power for the entire system.
To Heater fan wiring
