Up-date to the org. post { CF vs TPI}
418 sbc are just nice starter motors for a 815 cu. BBC if only there packaging were a little smaller. All kidding aside someone can always bring up a bigger engine can out do a smaller one.
If anything others rent into a rant of why are you trying to talk this system up. So don't let it bother you if they have a closed mind to it.
btw the 12 means how many cly. the...V.....means V-configuration (like V-8) AND the last # means how many cid. is in each cly..... so 12V71 is 852cid total! hammer down!
There was a guy in the 60s built a fiberglass body off of his 34 ford sedan put a V12 allison aircarft engine in it. First place he went in it down to the local car hop for a burger lol. Thinking he called it, Lil Al.
I have been tempted to take an old KW conventional truck i have build a new frame for it remove the front axle of the tandum. Chrome up the 3406 cat a bit make a pickup out of it.
There was a guy in the 60s buit a fiberglass body off of his 34 ford sedan put a V12 allison aircarft engine in it. First place he went in it down to the local car hop for a burger lol.
Wake the dead in DD build at full throttle and hit the jake w/straight pipes! yep!
btw if ya use a ole DD 2-stroke make sure ya got splash shields for oil leaks! EVERYWHERE!
And expect very low mpg's!
omg yes LOL a lil nose heavy! however VERY impressive! jus think HOW many Vette owners can claim there engine has Twin Turbos AND 2 superchargers???
down!
turn the boost up & fuel!!! no need for smoke screen jus hit the throttle!
down! wait a min! this b Vette Forum!
The KW lowered and chromed out hellya now THAT would b a pic-up!! NO lack of torque w/3406!!!
down! and OF COURSE u could get a lil more w/ retro roller cam/rockers$$$$[high rpm gain there] and aluminum heads$$$$ probably increase comp/10.5:1 and keep detenation......at bay? however ALL THAT woulda cost about as much as the entire engine build? put n ya at or above $5,000 on cost w/ NO more than MAYBE a 30-40hp increase, and doubt that much???? [$$$$ vs potential vs hp vs cid vs cfm ], REMEMBER! your limited by CF/intake and Tb's. So if I can ONLY get 375hp out of my 355cid Vette and on the cheap! and keep n it comparativly stock I'M HAPPY!
plus a few tricks I used from past success & failures......get the RIGHT combination STARTING w/CFM vs CID, then build the rest to that # so 383-400 and stock CF-intake IMHO No.[w/Renagade YES!] To each there own, good luck!
