Dead battery help please?
Old Jun 14, 2002 | 11:53 PM
Stevo81's Avatar
Stevo81
Default Dead battery help please?
Got a fairly new battery going dead after sitting for a few days. What is best way to find drain? Have multimeter. Thanks. Stevo
Old Jun 15, 2002 | 01:24 AM
Heyward's Avatar
Heyward
Default Re: Dead battery help please? (Stevo)
The solution with my '75 was a battery kill switch to turn off any time the car was going to sit for any length of time. I could have eventually found and repaired all the shorts and / or drains, but I had been concerned with the possibility of an electrical fire with this old of a car. I kept wondering what I would do if, while driving down the road I suddenly noticed smoke start coming out of the dash. I bought a keyed battery disconnect. I mounted it behind the drivers seat into the battery compartment. Now if the car is going to sit for any time, I reach behind the seat and turn the key. It is also an added anti-theft measure. 3 birds with 1 stone - 1) immediately kill all power in case of electrical fire - 2) stops the battery from going dead while sitting inactive - 3) makes it harder to steal
Old Jun 17, 2002 | 12:01 PM
The Money Pit's Avatar
The Money Pit
My 80 did the same . I put my multimeter in seriies with the battery positive (Set the meter to read AMPS) and found I was pulling 10 Amps with nothing turned on. Started pulling fuses till the cuuent went to zero.
It seems the burg alarm was the problem. Chop,chop,snip,snip, no more dead battery.
Old Jun 17, 2002 | 12:08 PM
mg62's Avatar
mg62
There is some really detailed info on this subject in the following thread. Check it out:
http://forums.corvetteforum.com/zerothread?id=303299
To Dead battery help please?
